Bridge syntax
I am trying to use the Bridge example code to set digital pins on the Yun, but I am confused on the way to structure the commands in the browser.
The example says: http://myArduinoYun.local/arduino/digital/13/1 to set pin 13 high and …13/0 to set pin 13 low.
Since my particular Arduino is named StationOneA and has a password of Station1A, I presume the command should be this in the browser bar: http://StationOneA.local/Station1A/digital/13/1 or …13/0
Do I understand correctly?
Dean
No, the /arduino in the url is not the name of the board, which is specified in the hostname (the part right after http://)
