Broadcom Absolute Rotary Encoder
Hello,
I am having difficulty reading data from my SSI Broadcom rotary encoder (AS38-H39E-S13S). Data that keeps being read is 0. Still relatively new to using SSI, but it is hooked up using a RS485 IC (SN65LBC179) and the data+/data- pins are terminated with a 120 ohm resistor. I do not believe that it is a wiring issue, but more of code and timing because if I run a clock data seems to be coming through. Any help would be most appreciated!
const int CLOCK_PIN = 5;
const int DATA_PIN = 6;
const int BIT_COUNT = 39;
  //setup our pins
  pinMode(DATA_PIN, INPUT);
  pinMode(CLOCK_PIN, OUTPUT);
  //give some default values
  digitalWrite(CLOCK_PIN, HIGH);
  Serial.begin(19200);
  Serial.print("Reading: ");
  for(int i = 0; i<BIT_COUNT; i++)
    unsigned int data = 0;
    noInterrupts();
    digitalWrite(CLOCK_PIN, LOW);
    for(int x = 0; x < 6; x++)
      __asm__ __volatile__ ("nop\n\t"); //Delay 437.5 nanoseconds
    for(int x = 0; x < 59; x++)
      __asm__ __volatile__ ("nop\n\t"); //Delay 3.75 microseconds
    data = digitalRead(DATA_PIN);
    Serial.print(data);
  interrupts();
