Broken Servo. Help please :(
Does anyone know where i can get a replacement servo main board for a Power HD 1711MG servo? I can't seem to find anywhere online to buy servo mainboards. I paid 25$ for this one at a local electronics store. I don't want to have to buy another servo just because i was being stupid.
How it happened: so i was being a careless noob today cause i got like 1 hour of sleep last night. -.- i should know better than to mess with electronics when im not competent to do so. But i didn't, so i hooked the positive wire of a 4 AA battery box to the negative terminal on the servo, and i hooked the negative to the positive. Next thing i know there is smoke coming out of the servo, the insulation on the wires melt near where the wires go into the servo box. :( so i open up the servo to look at the damage and the servo wires even came unsolder-ed -.-
It might not be dead. Resolder the wires and see if it works. Some electronics are surprisingly robust.
I don't know of anyplace that sells replacement "stock" electronics for commercial servos. Sparkfun has an "openServo" board (replacement electronics with increased capabilities; only slightly more expensive than a full new servo that it would fit int.)
If all else fails, Pololu has that for under $13 http://www.pololu.com/catalog/product/2144
Ouch! Sorry to hear about your smoke :cold_sweat:
Only worse thing would be to stop trying stuff out.
I have some (DISCLAIMER) low-cost servos here: http://arduino-direct.com/sunshop/index.php?l=product_list&c=10
How much torque do you need??
