Hi all,
I've accidentally ripped the USB socket off my Arduino micro. I have no chance to solder the connector back to the board as the tracks are damaged..
I am now trying to find an alternative way of programming it.
I've found this other thread that explains how to use another Arduino (in my case I have an Uno R3 I can use): http://forum.arduino.cc/index.php/topic,7571.0.html
It works well when I use this method to program an Arduino Pro Mini (the same that is being used in the above link).
However, when I try to reproduce the method on the Arduino Micro, I get an "Uploading.." that takes forever.
I am using the following connections:
5V -> Vin
GND -> GND
RX -> RX
TX -> TX
RESET -> RESET
I've enabled verbose on upload and I get the following output:
Binary sketch size: 4,830 bytes (of a 28,672 byte maximum)
Forcing reset using 1200bps open/close on port COM5
PORTS {COM1, COM5, } / {COM1, COM5, } => {}
Uploading using selected port: COM5
C:\Program Files\Arduino\hardware/tools/avr/bin/avrdude -CC:\Program Files\Arduino\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega32u4 -cavr109 -P\\.\COM5 -b57600 -D -Uflash:w:C:\Users\rema\AppData\Local\Temp\build2843951996578033340.tmp\Blink.cpp.hex:i
avrdude: Version 5.11, compiled on Sep 2 2011 at 19:38:36
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files\Arduino\hardware/tools/avr/etc/avrdude.conf"
Using Port : \\.\COM5
Using Programmer : avr109
Overriding Baud Rate : 57600
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 1024 8 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : butterfly
Description : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: Send: . [1b]
avrdude: Send: S [53]
avrdude: Recv:
avrdude: Recv:
avrdude: Send: V [56]
avrdude: Recv:
avrdude: Send: v [76]
avrdude: Recv:
avrdude: Recv:
avrdude: Send: p [70]
avrdude: Recv:
Found programmer: Id = "®ÿ""; type = ¤
Software Version = E.
Software Version = E.; Hardware Version = ð.
avrdude: Send: a [61]
avrdude: Recv:
avrdude: Send: b [62]
avrdude: Recv:
avrdude: error: buffered memory access not supported. Maybe it isn't
a butterfly/AVR109 but a AVR910 device?
Am I doing anything wrong ? Can I even do that actually ?
I'm a bit lost here, a little help would be much appreciated
