Brushless ESC Calibration Help
I want to make an RC plane, everything was going great with the ESC and the motor until i changed the code and it stopped working normally, I tried calibrating several ways but it just doesn't work, here's an example of my code:
#include <Servo.h>
Servo mot;
  mot.attach(8);
  Serial.println("Waiting 5 seconds untril calibration");
  delay(5000);
  Serial.println("Sending max throttle");
  mot.writeMicroseconds(2000);
  delay(5000);
  Serial.println("Sending min throttle");
  mot.writeMicroseconds(1000);
  delay(5000);
  Serial.println("ESC calibration done!");
  // Idle throttle
HI, @kokorakabobo_max
Welcome to the forum.
Can you please post your working code?
Tom.... :smiley: :+1: :coffee: :australia:
Sure, this code was used to test the esc and it worked perfectly:
#include <Servo.h>
Servo mot;
  mot.attach(8);
  mot.writeMicroseconds(2000);  // Send full throttle (MAX)
  delay(2000);                  // Wait for ESC to detect max (should beep)
  mot.writeMicroseconds(1000);  // Then send min throttle
  delay(3000);                  // ESC should confirm with a few beeps
  // Try different throttle values
  mot.writeMicroseconds(1200);
  delay(3000);
  mot.writeMicroseconds(1500);
  delay(3000);
  mot.writeMicroseconds(1800);
  delay(3000);
Well the setup codes are different.
Why did you change the setup when you know it works?
Try this...
#include <Servo.h>
Servo mot;
  mot.attach(8);
  // Idle throttle
I make RC electric planes. What do you think a servo is going to do under throttle control? My smallest planes have 14,000 RPM brushless motors. I never heard of a continuous servo capable of that speed, but go ahead and educate me.
Have you tried my code?
No, I have no interest in it.
Why, it is just your codes combined.
How do you want us to help you?
I tried your code in post #1 and it compiles clean. What does it do or not do?
Sorry we crossed paths. I am a helper not the op.
No problem.. coffee deficiency....
@kokorakabobo_max This is a pointless exercise. RC planes have propeller rpm's of 14,000 RPM, a servo is only capable of 200 RPM max.
What is needed is a Brushless DC Motor, commonly known as a BLDC. Here is the specs for one of my motors https://amz.cx/3Qi7
If I bought the 1100KV motor and used a battery pack of 3S then the RPM is 1100 X 3 X 3.7 which is 12,210 RPM
