Brushless Motor and Arduino Nano 3 board - Code - COVID Blower
Hello all,
I am trying to follow some schematics from someone in this community in regards to building a blower respirator which I find very interesting for my personal knowledge. This one LEE’s Project
I have done almost all, the circuit seems to be correct, however, the Motor is giving me that beep when I power the circuit.
I was looking in different forums and it seems that there seems to be some missing code to initialize the servo, I am new to Arduino.
What is the problem?
The Motor makes a beep every second and it doesn’t start
The question to the forum:
How can I fix this?
My motor is this one: Motor DualSky Track and field Brushless 5.5 turn Sensored Motor OZRC
So far this has been achieved and seems to be correct.
Lee’s code is this one:
#include <Servo.h>
Servo myservo;
//some variables to tweek
#define version "20200316.2"
#define rate 16 // breathing cycles per minute
#define enable_motor true // useful for debugging without noise
#define max_speed 180
#define min_speed 0
#define PEEP_speed 40 //approx 5cm/H2O
#define led_pin 13
#define button_pin A5
#define current_pin A0
#define servo_pin 3
#define serial_baud 9600
int buttonState = 1;
int buttonStatePrev = 1;
int speed_state = 0;
int loop_count = 0;
int click_loop_count = 0;
int click_count = 0;
int target_speed_high = 0;
int target_speed_low = 0;
int cycle_counter = 0;
int cycle_phase = 0;
int mode = 0;
int current = 0;
  Serial.begin(serial_baud);
  Serial.print("Version:\t");
  Serial.println(version);
  pinMode(led_pin, OUTPUT);
  pinMode(current_pin, INPUT);
  analogReference(INTERNAL); // sets reference to 1.1v
  pinMode(button_pin, INPUT_PULLUP);
  digitalWrite(led_pin, HIGH);
  if(enable_motor){
    myservo.attach(servo_pin,1000,2000); // some motors need min/max setting
    Serial.print("Initializing ESC...");
    myservo.write(max_speed);
    delay(3000); // wait for esc to boot, and sample maximum
    myservo.write(min_speed);
    digitalWrite(led_pin, LOW);
    delay(2000);  // wait for esc to sample minimum
    myservo.write(PEEP_speed);
    Serial.println("Done");
    Serial.println("Motor disabled.  Bypassing initialization");
  buttonStatePrev = buttonState;
  buttonState = digitalRead(button_pin);
  // button down event, accumulate number of clicks and time of first click
  if(buttonState == 0 and buttonStatePrev == 1){
    click_loop_count = loop_count;
    click_count += 1;
  if(click_count > 0){
    // past click count timeout
    if(click_loop_count + 30 < loop_count){
      if(click_count == 1){ // single click
        speed_state = (speed_state + 1)%5;
        if(mode == 0){
          cycle_counter = 10000; // if in CPAP mode update immediately
      if(click_count == 2){ // double click
        mode = (mode +1)%2;
        // if entering PEEP mode, update immediately in exhale cycle
        // otherwise, maintain phase
        cycle_phase = 0;
      // blink LED
      delay(50);
      // print state
      Serial.print(loop_count/100.0);
      if(mode == 0){
        Serial.print("\tset to CPAP level: ");
        Serial.println(speed_state);
      if(mode == 1){
        Serial.print("\tset to PEEP level: ");
        Serial.print(speed_state);
        Serial.print("\tforced rate: ");
        Serial.print(rate);
        Serial.println("/min");
      click_count = 0;
  // approximate pressure mapping fro original blower. Other blowers will vary
  // 40 ~= 5cm/H2O
  // 60 ~= 10cm/H2O
  // 90 ~= 18cm/H2O
  // 120 ~= 32cm/H2O
  if (speed_state == 0) {
    target_speed_high = 60;
    target_speed_low = PEEP_speed;
  if (speed_state == 1) {
    target_speed_high = 70;
  if (speed_state == 2) {
    target_speed_high =  80;
  if (speed_state == 3) {
    target_speed_high =  90;
  if (speed_state == 4) {
    target_speed_high =  100;
  //CPAP mode, both speed are the same
  if(mode == 0)
    target_speed_low = target_speed_high;
  // handle breath in/out cycle at target rate/min
  cycle_counter += 1;
  if( (30*100)/rate < cycle_counter){
    cycle_phase = (cycle_phase+1)%2;
    cycle_counter = 0;
    Serial.print("\tphase speed:");
    if(cycle_phase == 0){
     if(enable_motor)
        myservo.write(target_speed_high);
      Serial.println(target_speed_high);
     if(enable_motor)
        myservo.write(target_speed_low);
      Serial.println(target_speed_low);
  // for debugging breathing back pressure sensing
//  current = analogRead(current_pin);
//  Serial.print(current);
//  Serial.print(",");
//  Serial.println(digitalRead(button_pin));
  loop_count += 1;
  delay(10);  // approximately 100 cycles per second
It seems that the ESC is receiving an invalid pulse.
I assume that the ESC is the red board on your post. Can you link that product here?
Share the circuit diagram. As this project looks quite buggy so problem's must be in circuitry.
