Im looking to controle a motor that will make very small step. (less than 1 degre).
And in the same time i will like the feedback to know what is the position of the motor.
I read about this subject but some people tell that this can be done by Servo motors and others Brushless motor (because many use this for Brushless Gimbal Camera)
With a brushless motor you need to build some kind of feedback. And brushles motors need a special driver (a module that controls the motor).
A servo motor can be used to set an angle of 0 to 180 degrees.
The Arduino Servo library uses steps of 1 degree.
A stepper motor makes small steps. There is no feedback, since you know how many steps have been taken.
A stepper motor has very little strength, the faster it turns the less strength.
The Arduino stepper library can be used, but there are also many good driver boards.
For super small steps, you can use a stepper motor with gears. That way you can achieve less than 1 degree.
My testing of typical hobby servos found that a hobby servo is mechanically capable of about .5 deg resolution. One would use the writeMicroseconds() functions for this.
PAKOLG:
but if i need very good speed, big torque, and a very good precision (repetability) is it best a servo motor or a brunsh less sterpper with feedback?
I don't know. Get a cheap servo and find out what it can do. If it is not suitable then you know you need a more complex solution.
By the way, while it is true that stepper motors are brushless the two words are not normally used together. Brushless motor usually means an entirely different thing that does not have steps.
