Brushless Motor ServoTimer2
I am trying to make a drone using the VirtualWire library, but to control a brushless motor ESC (I think) you need to use a servo library, but the standard servo library conflicts with the VirtualWire library. I have not found any great sources of how to use a brushless motor with the ServoTimer2 library, does anyone have any ideas? Thanks!
Controlling ESCs is the same as controlling servos and I know you can do that from your previous threads. For an ESC write(600) is stop, write(2400) is full speed. Values may change a bit, depending exactly what ESC you have.
Steve
Ok, thanks!
