BT control servos
So I have two servos modified to rotate 360 degrees and I have code that works odd. I want my robot to be controled both with bluetooth and infra-red. And I have an ultrasoinc sensor to messure the distance and stop if there is an object in front of it, then go back to safe distance and enable the user to control it again.
Now, the IR control works fine, and ultrasonic sensor works fine. it messures the distance and the robot goes back until safe dinstance, but the part da doesn't work is bluetooth cotrol.
The arduino recives data from my phone I use the "Bluetooth RC Controller" app and sometimes the servos move smoothly but then sometimes they just move in little bits. While the IR control works fine always, and the servos always move smoothly.
I also noticed that the servos always rotate smoothly when reciving both IR and BT data.
Here is my code :
#define bluetooth Serial
char c;
#include<Ultrasonic.h>  /*include user installed library*/
    Ultrasonic ultrasonic(6, 7); /*create instance of ultrasonic and define pins*/
#include <Servo.h>
    Servo leftServo;
    Servo rightServo;
#include <IRremote.h>
    int IRpin = 11;  // pin for the IR sensor
    IRrecv irrecv(IRpin);
    decode_results results;
        leftServo.attach(9); //old servo is 9 and 11
        rightServo.attach(10);
         delay(500); // wait for bluetooth module to start
        bluetooth.begin(115200); // Bluetooth default baud is 1152
        irrecv.enableIRIn(); // Start the receiver
        leftServo.write(100);          // neutral position
        rightServo.write(93);
       Serial.print(ultrasonic.Ranging(CM));  /* INC for inches, CM for centimeters */
       Serial.println("cm");
    while (ultrasonic.Ranging(CM) >= 5 )
                  if (irrecv.decode(&results) )
                          irrecv.resume();
                         delay(50);// Receive the next value
                       if  (bluetooth.available()){
                        Serial.print("done");
                  c = (char)bluetooth.read();
                      if ((results.value == 5316027) || (c == 'F'))  // up
                              leftServo.write(180);
                              rightServo.write(0);
                              delay(100);
                      if (results.value == 2747854299 || (c == 'B'))  // down
                              leftServo.write(0);
                              rightServo.write(180);
                              delay(100);
                      if (results.value == 553536955 || (c == 'R'))  // right
                              rightServo.write(85);
                              delay(100);
                      if (results.value == 1386468383 || (c == 'L'))  // left
                              leftServo.write(95);
                              delay(100);
                      if (results.value == 3622325019 || (c == 'S'))  // okay
                              delay(100);
     while (ultrasonic.Ranging(CM) <= 5)
                  leftServo.write(0);
                  delay(100);
            results.value = 3622325019;
            irrecv.resume();
            c = 'S';
The value that you print has nothing to do with the value that you use. Why bother printing what you don't use?
                          irrecv.resume();
There doesn't seem to be a point to sticking your head in the sand when the remote is used. Why do you?
Why do you not take any action when the remote is used?
Are you using Serial to talk to the blue tooth device OR to talk to the PC? Both is the wrong answer. So is yes.
All those delay()s are useless. If the user wants to go forward, what that SHOULD mean is "go forward until I tell you to go another direction". THAT does NOT involve delay().
