i must set the baud rate to 57600
this is the module
http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=220809927558&ssPageName=ADME:X:RTQ:US:1123
at the end of page there are some instruction...
could you help me?
this is the module
could you help me?
Pio 11 is problably the pin on the top right (holding the board with antenna up and and the 4 pin connetor down.
You have to supply 3,3 volt through a 10k ohm resistor to this pin and then power up the board. Then you will enter the AT mode from the board.
Thanks
What command i should send? ![]()
Well all those modules are hardware wise similar, but the firmware is different. So commands can be different.
It's just trial and error. As it can also be:
http://iteadstudio.com/store/index.php?main_page=product_info&cPath=7&products_id=157
There AT mode change example look similar to this:
So i should connect the 3.3V arduino port with a 10kohm resistor to pin11
And connect the module's GND with arduino's GND
After i pair the module with PC and with HyperTerminal i send this: \r\n+STBD=57600\r\n
No you need a usb to serial TTL adapter.
You can use the arduino for this.
You connect the following from the arduino to the bluetooth device
RX to TX
TX to RX
GND to GND
3,3v trough a 10k resistor
Power up the arduino
Now connect 5V to 5v
Open a terminal program.
Now you can use AT commands.
The AT coomand could also be:
AT+UART=57600?1,2,\r\n
It looks like the key pin goes to pio11 <- not pin 11 !!!!
Thanks
Probably i've found the correct manual... HC-06
but it tell:
The way to the AT command mode: supply power to the module, it will enter to the AT mode if it needn’t pair. The interval of command is about 1 second. Default parameter: Baud rate:9600N81, ID: linvor, Password:1234
I can't understand this.....
http://www.elecfreaks.com/wiki/index.php?title=Bluetooth_Bee
Well that's Engrish. I think wat the mean is that when their is no bleutooth connection and you fast enough (1 second window) you can go into AT mode by sending the AT command in a continious row, like:
AT
AT
AT
AT
But I'm also struggling with one of these modules. I do have the HC05 firmware, which I could load and enable all the goodies.
