BTbee pro
Hey guys, I'm using a BTbee pro with the arduino but it doesn't seem to work so I was wondering if there is a library that i should install before i can use the BT module If there is one plz send it to me or you could just send me a link thanks in advance X)
No library needed. Bluetooth devices are serial devices, usually. Just treat it as a serial device.
That's almost always lame enough to keep me from responding, but I made an exception in this case.
The code you didn't post does something with the hardware you didn't describe. Clearly, what it actually does is not what you want, but it is not clear what it does or what you want.
char val; // variable to receive data from the serial port
int ledpin = 8; // LED connected to pin 48 (on-board LED)
  pinMode(ledpin, OUTPUT); // pin 48 (on-board LED) as OUTPUT
  Serial.begin(9600); // start serial communication at 9600bps
  if( Serial.available() ) // if data is available to read
    val = Serial.read(); // read it and store it in 'val'
  if( val == 'H' ) // if 'H' was received
    digitalWrite(ledpin, HIGH); // turn ON the LED
  } else {
    digitalWrite(ledpin, LOW); // otherwise turn it OFF
  delay(100); // wait 100ms for next reading
This is the code
and this is the configuration of the BTbee pro :
http://www.electronicaestudio.com/docs/istd019.pdf
The code works perfectly in the serial monitorbut i tried to send data from an android device to the arduino but it didn’t work
I noticed that there is a connection between the android device and the BT module but there wasn’t any connection between the arduino and the BT module
This is the code
That nonsense? If you used Copy for forum, don't. Ctrl-A, Ctrl-C, Ctrl-V to select all, copy, and paste (after clicking the code icon (#)).
