Hi everyone, I'm new here and new to Arduino with a small amount of projects under me. I recently built the Back to the Future alarm clock and have been struggling with the 12 hour format for alarms. Using the code provided with the project it handles the 12 hour clock and display correctly, however when setting an alarm it is still in 24 hour format. The 24 hour alarm format is not a big deal, but after setting the alarm for PM hours it will revert the set time to AM therefore not alarm. I also noticed if I set the alarm for AM (ex..5:30) the alarm will go off at 1:30. I'm wondering if it is better to load a different library and redo the existing. Any suggestions or direction would be helpful.
`#include "WiFiManager.h"
#include "NTPClient.h"
#include "TM1637Display.h"
#include "DFRobotDFPlayerMini.h"
#include "Adafruit_NeoPixel.h"
#include <EEPROM.h>
//========================USEFUL VARIABLES=============================
const char *ssid = "";
const char *password = "";
int UTC = -4; //Set your time zone ex: france = UTC+2
uint16_t notification_volume= 25; //Set volume value. From 0 to 30
int Display_backlight = 3; // Set displays brightness 0 to 7;
int snooze = 5; // Snooze time in minute
#define DISPLAY_CLK 21
#define DISPLAY_DIO 22
#define SET_STOP_BUTTON 34
#define HOUR_BUTTON 33
#define MINUTE_BUTTON 32
#define FPSerial Serial1
#define PIN 4 // Neopixel pin
#define NUMPIXELS 24 // Popular NeoPixel ring size
#define EEPROM_SIZE 12
const byte RXD2 = 16; // Connects to module's TX => 16
const byte TXD2 = 17; // Connects to module's RX => 17
DFRobotDFPlayerMini myDFPlayer;
void printDetail(uint8_t type, int value);
float counter = 0;
int hours = 0 ;
int minutes= 0 ;
int flag_alarm = 0 ;
int alarm_on_off=1;
int h=0;
const long utcOffsetInSeconds = 3600; // UTC - 5H / Offset in second
int Play_finished = 0;
int easter_egg = 0;
// Define NTP Client to get time
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP, "pool.ntp.org", utcOffsetInSeconds*UTC);
TM1637Display red1(DISPLAY_CLK, DISPLAY_DIO);
Adafruit_NeoPixel pixels(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
pinMode(SET_STOP_BUTTON, INPUT);
pinMode(HOUR_BUTTON, INPUT);
pinMode(MINUTE_BUTTON, INPUT_PULLDOWN);
pinMode(26, OUTPUT);
pinMode(PIN, OUTPUT);
red1.setBrightness(Display_backlight);
pixels.setBrightness(0);
pixels.show();
//Init EEPROM
EEPROM.begin(EEPROM_SIZE);
minutes = EEPROM.read(0);
hours = EEPROM.read(1);
WiFi.begin(ssid, password);
while ( WiFi.status() != WL_CONNECTED ) {
delay ( 500 );
Serial.print ( "." );
timeClient.begin();
FPSerial.begin(9600, SERIAL_8N1, RXD2, TXD2);
Serial.println(F("DFRobot DFPlayer Mini"));
Serial.println(F("Initializing DFPlayer ... (May take 3~5 seconds)"));
if (!myDFPlayer.begin(FPSerial, /*isACK = */true, /*doReset = */true)) { //Use serial to communicate with mp3.
Serial.println(F("Unable to begin:"));
Serial.println(F("1.Please recheck the connection!"));
Serial.println(F("2.Please insert the SD card!"));
while(true){
delay(0); // Code to compatible with ESP8266 watch dog.
Serial.println(F("DFPlayer Mini online."));
myDFPlayer.volume(notification_volume);
myDFPlayer.play(10); //Play the first mp3
delay(100);
Play_finished = 0;
for(int v=0; v<30; v++){
pixels.clear();
for(int i=0; i<8;i++){
pixels.setPixelColor(i, pixels.Color(100,100,100));
pixels.setPixelColor((i+8), pixels.Color(100,100,100));
pixels.setPixelColor((i+16), pixels.Color(100,100,100));
delay(10);
pixels.setBrightness(20+v);
pixels.show();
for(int t=50; t>-1; t--){
pixels.setBrightness(t);
delay(40);
pixels.show();
Serial.println("\n Starting");
myDFPlayer.play(14);
pixels.clear();
show_hour() ;
h=1;
Play_finished = 0;
// Serial.print("Minutes EEPROM: ");
// Serial.println(EEPROM.read(0));
// Serial.print("Hours EEPROM: ");
// Serial.println(EEPROM.read(1));
timeClient.update();
Serial.print("Time: ");
Serial.println(timeClient.getFormattedTime());
unsigned long epochTime = timeClient.getEpochTime();
struct tm *ptm = gmtime ((time_t *)&epochTime);
int currentYear = ptm->tm_year+1900;
Serial.print("Year: ");
Serial.println(currentYear);
int monthDay = ptm->tm_mday;
Serial.print("Month day: ");
Serial.println(monthDay);
int currentMonth = ptm->tm_mon+1;
Serial.print("Month: ");
Serial.println(currentMonth);
if (timeClient.getHours() == 0)
hours = 12;
else if (timeClient.getHours() == 12)
hours = timeClient.getHours();
else if (timeClient.getHours() >= 13) {
hours = timeClient.getHours() - 12;
else {
if (myDFPlayer.available())
printDetail(myDFPlayer.readType(), myDFPlayer.read()); //Print the detail message from DFPlayer to handle different errors and states.
if (digitalRead(SET_STOP_BUTTON) == true)
Setup_alarm() ;
myDFPlayer.stop();
digitalWrite(26,LOW);
if (hours == timeClient.getHours() && flag_alarm == 0 && alarm_on_off == 1)
if (minutes == timeClient.getMinutes()) {
flag_alarm=1;
alarm();
Serial.println("Sortie alarm");
if(alarm_on_off == 1){digitalWrite(26,HIGH);}
else digitalWrite(26,LOW);
if(minutes != timeClient.getMinutes() )
{flag_alarm=0;}
if(easter_egg == 1){
pixels.clear();
pixels.setPixelColor(i, pixels.Color(255,110,14));
pixels.setPixelColor((i+8), pixels.Color(255,110,14));
pixels.setPixelColor((i+16), pixels.Color(255,110,14));
delay(20);
pixels.setBrightness(23);
pixels.show();
if(digitalRead(MINUTE_BUTTON) == true && digitalRead(HOUR_BUTTON) == true ) // Push Min and Hour simultanetly to switch ON or OFF the alarm
if(alarm_on_off == 1){alarm_on_off = 0;}
else alarm_on_off = 1;
red1.showNumberDecEx(00,0b01000000,true,2,0);
red1.showNumberDecEx(alarm_on_off,0b01000000,true,2,2);
if(digitalRead(MINUTE_BUTTON) == true ) // Push Min and Hour simultanetly to switch ON or OFF the alarm
if(easter_egg == 0) {
easter_egg=1;
myDFPlayer.play(12);
else {easter_egg = 0;
myDFPlayer.play(13);
pixels.show();
if((currentMonth*30 + monthDay) >= 121 && (currentMonth*30 + monthDay) < 331){
timeClient.setTimeOffset(utcOffsetInSeconds*UTC);} // Change daylight saving time - Summer
else {timeClient.setTimeOffset((utcOffsetInSeconds*UTC) - 3600);} // Change daylight saving time - Winter
void alarm() {
// count 0 to 88 m/h
for(int u=0; u<89;u++){
delay(12-(u/8));
red1.showNumberDecEx(u,0b01000000,true,2,2);
//Flux capacitor acceleration
pixels.clear();
pixels.setPixelColor(i, pixels.Color(255,(110+h),13+h));
pixels.setPixelColor((i+8), pixels.Color(255,(110+h),13+h));
pixels.setPixelColor((i+16), pixels.Color(255,(110+h),13+h));
delay(12-(h/8));
pixels.setBrightness(20+h);
pixels.show();
if(digitalRead(SET_STOP_BUTTON) == true){u=89;}
if(digitalRead(MINUTE_BUTTON) == true || digitalRead(HOUR_BUTTON) == true ) // Snooze if you push MIN or HOUR button
Snooze();
h=h+1;
myDFPlayer.play(random(1,9)); //Playing the alarm sound
delay(1500);
while(digitalRead(SET_STOP_BUTTON) == false)
h=1;
show_hour();
// Serial.println("dans la boucle");
// If you're not wake-up at the first song, it plays the next one
if(Play_finished == 1) {
Play_finished = 0;
Serial.println("Next song");
//That's bzzzz the Neopixel
pixels.clear();
pixels.setPixelColor(i, pixels.Color(255,200,105));
pixels.setPixelColor((i+8), pixels.Color(255,200,105));
pixels.setPixelColor((i+16), pixels.Color(255,200,105));
delay(5);
pixels.setBrightness(110);
pixels.show();
//Serial.println("Boucle neopixel");
Snooze();
pixels.show();
void show_hour(){
red1.showNumberDecEx(hours,0b01000000,true,2,0);
red1.showNumberDecEx(timeClient.getMinutes(),0b01000000,true,2,2);
// Snooze if you'd like to sleep few minutes more
// You can set the snooze time with the "snooze" variable at the beginning of the code
void Snooze(){
myDFPlayer.stop();
pixels.setBrightness(5);
pixels.show();
for(int i=0; i<(snooze*600);i++)
waitMilliseconds(68);
show_hour();
Serial.println("snooze");
Serial.println(i);
if(digitalRead(SET_STOP_BUTTON) == true){i=snooze*600;}
alarm();
Play_finished = 0;
void Setup_alarm() {
while (digitalRead(SET_STOP_BUTTON) == true)
if (digitalRead(MINUTE_BUTTON) == true){
minutes = minutes + 1;
if (digitalRead(HOUR_BUTTON) == true){
hours = hours + 1;
red1.showNumberDecEx(minutes,0b01000000,true,2,2);
delay(100);
if (minutes > 59){minutes=0;}
if (hours > 23){hours=0;}
EEPROM.write(0, minutes);
EEPROM.write(1, hours);
EEPROM.commit();
void printDetail(uint8_t type, int value){
switch (type) {
case TimeOut:
Serial.println(F("Time Out!"));
case WrongStack:
Serial.println(F("Stack Wrong!"));
case DFPlayerCardInserted:
Serial.println(F("Card Inserted!"));
case DFPlayerCardRemoved:
Serial.println(F("Card Removed!"));
case DFPlayerCardOnline:
Serial.println(F("Card Online!"));
case DFPlayerPlayFinished:
Serial.print(F("Number:"));
Serial.print(value);
Serial.println(F(" Play Finished!"));
Play_finished = 1;
case DFPlayerError:
Serial.print(F("DFPlayerError:"));
switch (value) {
case Busy:
Serial.println(F("Card not found"));
case Sleeping:
Serial.println(F("Sleeping"));
case SerialWrongStack:
Serial.println(F("Get Wrong Stack"));
case CheckSumNotMatch:
Serial.println(F("Check Sum Not Match"));
case FileIndexOut:
Serial.println(F("File Index Out of Bound"));
case FileMismatch:
Serial.println(F("Cannot Find File"));
case Advertise:
Serial.println(F("In Advertise"));
default:
default:
void waitMilliseconds(uint16_t msWait)
uint32_t start = millis();
while ((millis() - start) < msWait)
// calling mp3.loop() periodically allows for notifications
// to be handled without interrupts
delay(1);
