BTS 7960 43a motor driver code for Bluetooth control
hi
im doing a project on a RC car and im using the bt_2 (BTS 7960) h bridge module with 12 power source of 12 v and 4 amps !
i want to control the motor by bluetooth and i have the hc-06 ! forward and reverse
any ideas of working this together !!
this is the code that i tried but doesnt work
int motorPin1 = 3;
int motorPin2 = 4;
int enablePin = 5;
int state;
int flag=0;
pinMode(motorPin1, OUTPUT);
pinMode(motorPin2, OUTPUT);
pinMode(enablePin, OUTPUT);
digitalWrite(enablePin, HIGH);
if(Serial.available() > 0){
state = Serial.read();
flag=0;
if (state == '0') {
digitalWrite(motorPin1, LOW);
digitalWrite(motorPin2, LOW);
if(flag == 0){
Serial.println("Motor: off");
flag=1;
else if (state == '1') {
digitalWrite(motorPin2, HIGH);
if(flag == 0){
Serial.println("Motor: right");
flag=1;
else if (state == '2')
digitalWrite(motorPin1, HIGH);
if(flag == 0){
Serial.println("Motor: left");
flag=1;
thanks
Please modify your post and use the code button </> so your code looks like this and is easy to copy to a text editor.
What exactly do you mean by "doesnt work " ?
What tests have you carried out to try and figure out the problem?
Make a pencil drawing showing how everything is connected and post a photo of the drawing.
Post a link to the datasheet for your h-bridge.
How are you powering the motor and the Arduino?
...R
You probably should use the analog write method to operate the H-bridge. Check the BTS7960 data sheet on the requirements. The below discussion may have some info.
http://forum.arduino.cc/index.php?topic=148482.0
