bubble sorting arrays
I’ve got a mock array of temperature values. I can print it, but when I try to sort it, it doesn’t seem to work using the bubble array in my function, but I don’t know why.
It just prints the original array, which surprises me, since I declared the original array, temps, as a global variable so I thought it would get edited in the sorting function, and then be usable as a sorted array thereafter.
/***** GLOBAL VARIABLES *****/
const int arraySize = 10;
int temps[arraySize] = { 76, 77, 46, 83, 47, 55, 59, 34, 61, 83 };
int min_temp_value;
int max_temp_value;
int a = 0;  // used in for loop for printing raw temp data
bool printOnce = true;    // printing array data
bool printValues = true;  // print min and max temps
bool resetVars = true;    // reset vars to enable printing array data
/***** FUNCTION PROTOTYPES *****/
int sort_temps(int temps[]);  // takes temps array, and will sort, low to high into new array
int min_temp(int temps[]);
int max_temp(int temps[]);
  // print original array
  for (a; a < arraySize; a++)
       if (printOnce == true)
        Serial.print("raw temp data = { ");
        printOnce =! printOnce; // toogles true to false
      // test for last element in array
       if (a == (arraySize - 1))
           Serial.print(temps[a]);
           Serial.println(" }");  // end of data set
              Serial.print(", ");
  // function call to sort original array
  // print sorted array
    // reset vars to defults
    if (resetVars == true)
        a = 0;
        printOnce = true;
        resetVars =! resetVars;
        Serial.print("sorted temp data = { ");
              Serial.print(", ");
/***** FUNCTIONS *****/
// sort temp array, low to high
    int hold;
    // bubble sort, make 9 passes, as number of req. passes = arraySize - 1
    for (int passCounter = 0; passCounter < arraySize - 1; passCounter++)
        // number of comparisons per pass
        for (int i = 0; i < arraySize - 1; i++)
            // compare adjacent elements and swap them if left element is larger than next element to its right
            if (temps[i] > temps[i+1])
                hold = temps[i]; // stores left element, to be swapped into position to right
                temps[i] = temps[i+1];
                temps[i+1] = hold;
      // return temps; // returns temps array with its elements sorted from low to high
      return 0;  // don't need to return anything, as the fed in array, temps[], has been changed
for (a; a < arraySize; a++)Oops
That is not calling anything. That is only declaring a function prototype.
Cleaner version of code.
int temps[] = { 76, 77, 46, 83, 47, 55, 59, 34, 61, 83 };
const int arraySize = sizeof(temps)/sizeof(int);
int min_temp_value;
int max_temp_value;
void sort_temps(int temps[]);  // takes temps array, and will sort, low to high into new array
  for (int a = 0; a < arraySize; a++)
    if (a < (arraySize - 1)) Serial.print(", ");
  sort_temps(temps);
  int hold;
  bool swaps = true;
  while (swaps)
    swaps = false;
      if (temps[i] > temps[i + 1])
        swaps = true;
        temps[i] = temps[i + 1];
        temps[i + 1] = hold;
Got it! Thanks for the help, I fixed the issues. Not totally efficient, but it works. Below is my code. However, below that, is what I want to do now, is take the code, and instead of using pass-by-value into functions, I wanted to learn pass-by-reference. It’s new to me, so I took the original code (below), and tried to do my best to modify it to pass-by-value (which is below it). That’s where things go wrong.
// Pass By Value (original code - attached)
// Pass By Reference (new code)
/***** LIBRARIES AND HEADERS *****/
#include <stdio.h>  // what is this doing?
int min_temp;
int max_temp;
int temp_stats;     // will get sorted temps and min / max, used in loop
int sort_and_calc_temps(int temps[], int *min_temp, int *max_temp);  // takes temps array, and will sort, low to high into new array, then get min / max temps from it
//int min_temp(int temps[]);
//int max_temp(int temps[]);
                  Serial.print(", ");
temp_stats = sort_and_calc_temps(temps, &min_temp, &max_temp);
                     /* When passing the array into a function, you don't include the brackets [],
                       just the variable name
                       This allows the function call to reference the lvalue of the array.  This occurs since arrays are reference types, rather than value types.
      printOnce = true;
                  Serial.print(", ");
// print once
if (printValues == true)
   printValues =! printValues; // toggles so doesn't run again
  // print min temp
  Serial.print("min temp = ");
  Serial.println(&min_temp);
  // print max temp
  Serial.print("max temp = ");
  Serial.println(&max_temp);
// Follwing function does 3 things: (1) sort temp array, low to high, (2) calc min from new array (3) max from new array
int sort_and_calc_temps(int temps[], int *min_temp, *int max_temp)
    /***** Sorting Array of Raw Temps - Will Overwrite for New Array of Now Sorted Temps, Low to High *****/
    int hold;
                temps[i+1] = hold;     // new array of sorted temps has been created
        /***** Min temp from sorted array *****/
        *min_temp = temps[0]; // gets 1st element in array
        /***** Max temp from sorted array *****/
        *max_temp = temps[arraySize - 1]; // gets last element in array
  return hold; // it's an int to return, but unsure if I'll need to do anything with it
When I compile, I see several errors, but I want to start with just two:
  1. When compiling, I get errors msg in the function part of code (after loop):
Temperature_5_pass_by_reference:155:53: error: expected identifier before '*' token
Temperature_5_pass_by_reference:155:54: error: expected ',' or '...' before 'int'
  1. I get an error msg:
error: no matching function for call to 'println(int*)'
I’m confused here because I thoughts that:
*min_temp = &min_temp
*max_temp = &max_temp
Where should I start with to fix these?
Temperature_4_upload.ino (3.96 KB)
Let’s play spot the difference.
Serial.println(&min_temp); There is no overload of print that accepts an int pointer.
project_science:
I'm confused here because I thoughts that:
Yep, you seem a bit confused.
A variable 'max_temp' which can store an int...
int max_temp;
A pointer 'p_max' to that int variable (& gets the address of the memory location and puts it in the pointer 'p_max')...
int* p_max = &max_temp;
Entirely equivalent to...
int* p_max;
p_max  = &max_temp;
Setting the 'max_temp' variable via the pointer (* dereferences the pointer and sets what is in that memory location to the result of the expression)...
*p_max = 1234;
Printing/accessing the 'max_temp' variable directly...
Serial.println(max_temp);
Printing/accessing the 'max_temp' variable via the pointer (again * dereferences and gets what is in the memory location pointed to by the pointer)...
Serial.println(*p_max);
Edit:
By far the hardest part of this is getting your head round the fact that * has two usages:
  1. defining a pointer variable:
int* p_max;
  1. dereferencing that pointer to get at the actual variable (both read and write):
*p_max = 1234;
Wow, thanks for your input - I got the code to work! I fixed a dumb error in my function arguments, and I changed how I was printing.
int min_temp;
int max_temp;
int *ptr_min_temp = NULL;  // will be dereferenced, and equated to l-value of min_temp, so when referenced in print re-using *, it will print r-value of min_temp
int *ptr_max_temp = NULL;  // will be dereferenced, and equated to l-value of max_temp, so when referenced in print re-using *, it will print r-value of max_temp
                  Serial.print(", ");
      printOnce = true;
                  Serial.print(", ");
// print once
  // print min temp
  ptr_min_temp = &min_temp;  // passes address (l-value) of min_temp into r-value of var ptr_max_temp
  Serial.println(*ptr_min_temp);
  // print max temp
  ptr_max_temp = &max_temp;  // passes address (l-value) of max_temp into r-value of var ptr_max_temp
  Serial.println(*ptr_max_temp);
    int hold;
        *min_temp = temps[0]; // gets the address of where the 1st element in array is stored, and copies it to r-value of the pointer
        //ptr_min_temp = &min_temp;  // passes address (l-value) of min_temp into r-value of var ptr_max_temp
        *max_temp = temps[arraySize - 1]; // gets the address of where the last element in array is stored, and copies it to r-value of the pointer
        //ptr_max_temp = &max_temp;  // passes address (l-value) of max_temp into r-value of var ptr_max_temp
But I’m a bit confused why it works in some areas. Here’s what I think is going on:
When I called the function in the loop, I’m passing the pointers *min_temp and *max_temp, along with the temp array into the function sort_and_calc_temps. After sorting the array, I did the following:
This copies the address of where the 1st element of the array is stored into the r-value of the pointer. (The following does similar.)
By the function call, I passed the temp array, and the address of min_temp and max_temp into the function sort_and_calc_temps. This has the equivalent:
int *min_temp = &min_temp;
int *max_temp = &max_temp;
I then printed the values of the temps:
// print min temp
Here, I dereferenced the pointer *ptr_min_temp to the var int ptr_min_temp, and had it store the address of min_temp in its r-value.
I then printed the pointer *ptr_min_temp which, because it has access to the address of var min_temp, it thus printed the r-value of min_temp.
  1. Does this makes sense how I’ve described what’s occurring in my code?
  2. Why was I not able to put the following line in the function? It only let me use it in the loop:
