Buck converter for small wind turbine project
Greetings, I fabricated a Vertical Axis Wind turbine(VAWT) and Permanent Magnet Alternator(PMA). I have road tested the prototype and the max output was 9 amps @ 40 MPH while using 12 volt deep cell as a test load. Basically the faster you spin the PMA the more it acts like a electric brake and most of the energy being produced is lost at the stators as heat. I recently learned that Maximum Power Point Tracking(MPPT) will help solve this problem and allow more of the energy being product to be transferred to the load.
I have fabricated a Buck Converter(DC to DC Step Down Converter) which is the core circuit of a MPPT without the microcontroller and have verified the benefits of adding such a circuit to the system. The video shows manual operation of the PMA using the Buck circuit to drive a 50 watt 12 volt light. Max current was about 4 amp.
To produce the same results without using the Buck converter required a 30 MPH wind speed.
I am new to Uno, but have limited experience with other microcontrollers and software.
I am starting to develop the micro interface so a basic MPPT algorithm can be added.
Basic circuit requirements for Uno interface are:
  1. Read voltage and current at the output of the Buck converter.
  2. Output PWM signal to FOD3180 gate driver to control frequency and duty cycle of the IRF540 N channel mosfet.
Once the Input and Output circuits for the Uno interface are developed then a basic MPPT software algorithm can be written. If possible the Inputs and Outputs should be buffered to protect the Uno. I found a similar project that I am trying to use as a guide.
Any suggestion will be greatly appreciated. Thank you for your time a efforts.
Video’s of VAWT with no load, just for fun…
