Buffering data for SD card bug!!
I am trying to make a device that reads data from accelerometer/gyro/etc. and store the data into an SD card. I want to buffer a few reads from the sensors FIRST before writing data to SD card so that I can save power. But the weird thing is that when I adapted my code with the arrays to store data (instead of writing every time I read data). My code seems to behave differently in the setup stage.... (even though it was not CHANGED AT ALL).
Here is my code
// MPU-6050 Accelerometer + Gyro
#include <Wire.h> // Import I2C Library
#include <SD.h> // Import SD Card Library
#include "LowPower.h"// Import Low Power Library
//#include <stdlib.h> ;
File myFile;
#define MPU6050_I2C_ADDRESS 0x68
#define MPU6050_PWR_MGMT_1         0x6B   // R/W
#define MPU6050_CONFIG             0x1A   // R/W
#define MPU6050_ACCEL_XOUT_H       0x3B   // R
#define MPU6050_ACCEL_CONFIG       0x1C   // R/W
#define MPU6050_GYRO_CONFIG        0x1B   // R/W
typedef union accel_t_gyro_union
  struct
    uint8_t x_accel_h;
    uint8_t x_accel_l;
    uint8_t y_accel_h;
    uint8_t y_accel_l;
    uint8_t z_accel_h;
    uint8_t z_accel_l;
    uint8_t t_h;
    uint8_t t_l;
    uint8_t x_gyro_h;
    uint8_t x_gyro_l;
    uint8_t y_gyro_h;
    uint8_t y_gyro_l;
    uint8_t z_gyro_h;
    uint8_t z_gyro_l;
  } reg;
  struct
    int16_t x_accel;
    int16_t y_accel;
    int16_t z_accel;
    int16_t temperature;
    int16_t x_gyro;
    int16_t y_gyro;
    int16_t z_gyro;
  } value;
const int Buffer = 9;
volatile float globaltime;
String index;
volatile int length;
volatile int cycle;
volatile double a_x[Buffer];
volatile double a_y[Buffer];
volatile double a_z[Buffer];
volatile double g_x[Buffer];
volatile double g_y[Buffer];
volatile double g_z[Buffer];
volatile double t[Buffer];
volatile double light[Buffer];
volatile float time[Buffer];
 int error;
  uint8_t c;
  // Initialize the 'Wire' class for the I2C-bus.
  Wire.begin();
  //Serial.println("Initializing MPU");
  // Clear the 'sleep' bit to start the sensor.
  MPU6050_write_reg (MPU6050_PWR_MGMT_1, 0);
   // Incease low pass filter
  MPU6050_write_reg (MPU6050_CONFIG, 3);
   // Incease Accelerometer range to +- 8g
  MPU6050_write_reg (MPU6050_ACCEL_CONFIG, 16);
     // Incease Gyro range to +- 500 deg/sec
  MPU6050_write_reg (MPU6050_GYRO_CONFIG, 8);
  //Serial.println("Initializing SD Card");
   pinMode(10, OUTPUT);// CS pin is 10
  globaltime = 0;
  index = "";
    Serial.println("reading index");
    if (!SD.begin(10))
      //Serial.println("initialization failed!");
    return;
      myFile = SD.open("index.txt");
    if (myFile) {
    // read from the file until there's nothing else in it:
    while (myFile.available())
    	char letter = myFile.read();
        index += letter;
    // close the file:
    myFile.close();
    index += 'x';
    myFile = SD.open("index.txt", FILE_WRITE);
    Serial.println(myFile);
    myFile.print('x');
    myFile.close();
  length = index.length();
  index = (String)(index.length());
  index = index + ".csv";
  int leng = length + 1;
  char file[length];
  index.toCharArray(file,leng);
  delay(5);
  myFile = SD.open(file, FILE_WRITE);
  delay(5);
  myFile.println("The Product,Time since start (ms),Accel_x (g),Accel_y (g),Accel_z (g),Gyro_x (deg/s),Gyro_y (deg/s),Gyro_z (deg/s),Temperature (F), Light");
  delay(5);
  myFile.close();	// close the file
  cycle = 0;
  MPU6050_write_reg (MPU6050_PWR_MGMT_1, 0);// Wake Up MPU
  delay(40);
  ReadValues();
  MPU6050_write_reg (MPU6050_PWR_MGMT_1, 64);// Sleep MPU
  cycle += 1;
  if (cycle >= (Buffer))
    SDcardWrite();
    cycle = 0;
  LowPower.powerDown(SLEEP_120MS, ADC_OFF, BOD_OFF);
  void ReadValues()
  int error;
  double temp;
  accel_t_gyro_union accel_t_gyro;
  //Serial.println(F(""));
  //Serial.println(F("MPU-6050 reading"));
  // Read the raw values.
  // Read 14 bytes at once,
  // containing acceleration, temperature and gyro.
  // With the default settings of the MPU-6050,
  // there is no filter enabled, and the values
  // are not very stable.
  error = MPU6050_read (MPU6050_ACCEL_XOUT_H, (uint8_t *) &accel_t_gyro, sizeof(accel_t_gyro));
  // Swap all high and low bytes.
  // After this, the registers values are swapped,
  // so the structure name like x_accel_l does no
  // longer contain the lower byte.
   uint8_t swap;
  #define SWAP(x,y) swap = x; x = y; y = swap
  SWAP (accel_t_gyro.reg.x_accel_h, accel_t_gyro.reg.x_accel_l);
  SWAP (accel_t_gyro.reg.y_accel_h, accel_t_gyro.reg.y_accel_l);
  SWAP (accel_t_gyro.reg.z_accel_h, accel_t_gyro.reg.z_accel_l);
  SWAP (accel_t_gyro.reg.t_h, accel_t_gyro.reg.t_l);
  SWAP (accel_t_gyro.reg.x_gyro_h, accel_t_gyro.reg.x_gyro_l);
  SWAP (accel_t_gyro.reg.y_gyro_h, accel_t_gyro.reg.y_gyro_l);
  SWAP (accel_t_gyro.reg.z_gyro_h, accel_t_gyro.reg.z_gyro_l);
  // Print the raw acceleration values
  double x_g = accel_t_gyro.value.x_accel;
  double y_g = accel_t_gyro.value.y_accel;
  double z_g = accel_t_gyro.value.z_accel;
  a_x[cycle] = x_g/4096;
  a_y[cycle] = y_g/4096;
  a_z[cycle] = z_g/4096;
  temp = ( (double) accel_t_gyro.value.temperature + 12412.0) / 340.0;
  t[cycle] = (temp)*9/5 + 32;// Convert C to F
  // Print the raw gyro values.
  double x_s = accel_t_gyro.value.x_gyro;
  double y_s = accel_t_gyro.value.y_gyro;
  double z_s = accel_t_gyro.value.z_gyro;
  g_x[cycle] = x_s/65.5;
  g_y[cycle] = y_s/65.5;
  g_z[cycle] = z_s/65.5;
  light[cycle] = analogRead(A0);
    float clock = millis();
    globaltime = globaltime + 120;
    time[cycle] = ((globaltime + clock)/1000) * 1.0464;
void SDcardWrite()
  int i = 0;
  char file[length];
  while (i < cycle)
  if (myFile) {
    // Store in CSV format
    // Accel values
    myFile.print(",");
    myFile.print(time[i]);
    myFile.print(",");
    myFile.print(a_x[i], DEC);
    myFile.print(",");
    myFile.print(a_y[i], DEC);
    myFile.print(",");
    myFile.print(a_z[i], DEC);
    // Gyro values
    myFile.print(",");
    myFile.print(g_x[i], DEC);
    myFile.print(",");
    myFile.print(g_y[i], DEC);
    myFile.print(",");
    myFile.print(g_z[i], DEC);
    myFile.print(",");
    myFile.print(t[i], DEC);
    myFile.print(",");
    myFile.print(light[i], DEC);
    myFile.println("");
    //Serial.println("done.");
  i += 1;
  myFile.close();
  return;
// MPU6050_read
// This is a common function to read multiple bytes
// from an I2C device.
// It uses the boolean parameter for Wire.endTransMission()
// to be able to hold or release the I2C-bus.
// This is implemented in Arduino 1.0.1.
// Only this function is used to read.
// There is no function for a single byte.
int MPU6050_read(int start, uint8_t *buffer, int size)
  int i, n, error;
  Wire.beginTransmission(MPU6050_I2C_ADDRESS);
  n = Wire.write(start);
  if (n != 1)
    return (-10);
  n = Wire.endTransmission(false);    // hold the I2C-bus
  if (n != 0)
    return (n);
  // Third parameter is true: relase I2C-bus after data is read.
  Wire.requestFrom(MPU6050_I2C_ADDRESS, size, true);
  i = 0;
  while(Wire.available() && i<size)
    buffer[i++]=Wire.read();
  if ( i != size)
    return (-11);
  return (0);  // return : no error
The problem is when I change the "const int Buffer" to any value beyond 9. When I do that, the SD card fails to be able to WRITE to the card. And the weird part is that when I comment out the main loop, the setup stuff will work perfectly. What the setup step is supposed to do is read a file called "index.txt" and count that number of characters in it. After that I convert the character into an integer to use for the next name for the file I am writing to (e.g. 4.csv, 5.csv, etc...). In the setup I also have to add another character to the "index.txt" to make sure the next boot up I will have the next file name.
I am really baffled by this, anyone have an idea what is going on?? Ideally I want to be able to buffer a lot more data than just 9......
My guess is lack of memory. Which board are you using?
Oh, and there must be something missing. Where is MPU6050_write_reg()? I cannot compile that sketch.
Ok, I found something in some code on some dodgy playground site or something that I pasted in to get it to compile.
On an Uno:
  Flash: 67% (21616 bytes out of 32256 bytes max)
    RAM: 1590 bytes
         (text: 21362, data: 254, bss: 1336)
With there only being 2K of RAM you're rapidly filling up before you have even begun. 1336 bytes of that is uninitialised data, so things like your buffers, the SD card buffer, etc. 254 bytes of it is initialized data. My guess is strings that aren't forced to stay in RAM - things like
which would benefit from being wrapped in F():
myFile.println(F("The Product,Time since start (ms),Accel_x (g),Accel_y (g),Accel_z (g),Gyro_x (deg/s),Gyro_y (deg/s),Gyro_z (deg/s),Temperature (F), Light"));
Yep, that's had an impact:
    RAM: 1438 bytes
         (text: 21624, data: 102, bss: 1336)
52 bytes saved.
And on top of that you are using the String class, and doing silly things like:
I mean, now many scratch String objects will have been created just to do that? And then you go and convert it into a char array anyway. Why not just start as a char array and save yourself a huge memory hole?
Oh yes, and:
        index += letter;
That's crash city right there.
@majenko
Thank you very much for your replies. I am currently using an arduino mini pro 8 MHz.
Yea the code isn't complete because I ran out of space on the forum to completely put my whole code on.
the rest of the code should have been
// MPU6050_read
  int i, n, error;
  if (n != 1)
    return (-10);
  if (n != 0)
    return (n);
  i = 0;
  if ( i != size)
    return (-11);
// MPU6050_write
// This is a common function to write multiple bytes to an I2C device.
// If only a single register is written,
// use the function MPU_6050_write_reg().
// Parameters:
//   start : Start address, use a define for the register
//   pData : A pointer to the data to write.
//   size  : The number of bytes to write.
// If only a single register is written, a pointer
// to the data has to be used, and the size is
// a single byte:
//   int data = 0;        // the data to write
//   MPU6050_write (MPU6050_PWR_MGMT_1, &c, 1);
int MPU6050_write(int start, const uint8_t *pData, int size)
  int n, error;
  n = Wire.write(start);        // write the start address
  if (n != 1)
    return (-20);
  n = Wire.write(pData, size);  // write data bytes
  if (n != size)
    return (-21);
  error = Wire.endTransmission(true); // release the I2C-bus
  if (error != 0)
    return (error);
// MPU6050_write_reg
// An extra function to write a single register.
// It is just a wrapper around the MPU_6050_write()
// function, and it is only a convenient function
// to make it easier to write a single register.
int MPU6050_write_reg(int reg, uint8_t data)
  int error;
  error = MPU6050_write(reg, &data, 1);
  return (error);
Yea my coding skills are not that good :confused: my background is in EE. I will take in all your recommendations.
Wait so is it possible to store my buffers in the flash as opposed to RAM? if I have flash space left, should I just be using PROGMEM to store in flash?
thanks!!
anjianwu:
No. You can only store constant unchanging things in the flash, like string literals. And then of course only if the function you are using them with supports it (which the SD card functions unfortunately don't) - so anything with print or println with the contents in quotes can be "flashified".
The pro mini... That's a 168 on there isn't it? You only have 1K of ram on a 168, so you're already over budget - it's no wonder it's not working.
Half your RAM will be taken up with the SD card's 512 byte buffer, so you only have 512 bytes left to play with. The Arduino API takes up some of that by itself, leaving you really with just a few hundred bytes left for your data.
Every float or double (they are the same thing) takes 4 bytes. Every int (except "const" ints) takes 2 bytes. String objects are notoriously bad at behaving in small amounts of ram (they alloc(), realloc() and free() ram in the heap like nobody's business leaving it so riddled with holes it becomes impossible to allocate more than a handful of bytes at a time).
If you want to buffer data with such a small amount of RAM you will have to look at external storage - SPI connected SRAM chips are simple enough to get working, you just have to read and write them similar to the EEPROM.
Or use a chip with considerably more RAM in it.
