[Bug]-[Arduino-0022]-[ArduinoTestSuite.cpp]-enum ends with comma
I tried compiling the ArduinoTestSuite.cpp, and I got an error on the enum below. The problem is, that the last item in the enum ends with a comma. When removing the comma, it compiles fine.
Snippet from version 0022 ArduinoTestSuite.cpp:
enum
    ATS_Manufacturer    =   1,
    ATS_CPU,
    ATS_GCC_version,
    ATS_LIBC_version,
    ATS_CompiledDate,
    ATS_TestSuiteName,
    ATS_FreeMemory,
Hmmm seems like nobody cares...
I think it's really sloppy, and it proves that code changes are made and released for "production" without testing or even compiling the modified code! :astonished:
Lack of reply does not indicate lack of care.
Not necessarily. It is possible the person who wrote the code is using a different version of the compiler than you are using; a version that accepts that syntax. It could have been a simple oversight.
The code in question is technically not "production". It was used to help port the core to various boards. I suspect it was included with the distribution so that folks like you would have an opportunity to play with it, critique it, and possibly enhance it. I believe the ultimate goal is to provide a set of sketches the user can run to determine if their board is functioning correctly.
There does appear to be a lack of communication regarding the Test Suite. But a lack of communication is one of the barbs we must endure with open source projects.
Jeroenvw: When removing the comma, it compiles fine.
On some compilers, the final enum can have a comma, while on others, no. Can't seem to find out what the C standard allows, so it may not be sloppy code, just code written on another compiler.
Hmm I didn't know that... my understanding is that most compilers do not allow it. Most people use gcc/g++ and I think these compilers do not support it. That's why I think it would be nice if in the next release the comma is ommited :)
Thanks and happy coding!
