Hallo Arduino Team
I use Arduino 1.8.16 IDE and AVRISP mkII programmer.
When I use the right arrow to build and upload a sketch I get an error:
Arduino: 1.8.16 (Windows 10), TD: 1.55, Board: "Arduino Nano, ATmega328P"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\rolfd\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\rolfd\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\rolfd\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -vid-pid=07FD_000B -ide-version=10816 -build-path C:\Users\rolfd\AppData\Local\Temp\arduino_build_603873 -warnings=none -build-cache C:\Users\rolfd\AppData\Local\Temp\arduino_cache_556491 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=C:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose C:\Users\rolfd\AppData\Local\Temp\arduino_modified_sketch_482131\Blink.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\rolfd\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\rolfd\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\rolfd\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -vid-pid=07FD_000B -ide-version=10816 -build-path C:\Users\rolfd\AppData\Local\Temp\arduino_build_603873 -warnings=none -build-cache C:\Users\rolfd\AppData\Local\Temp\arduino_cache_556491 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=C:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose C:\Users\rolfd\AppData\Local\Temp\arduino_modified_sketch_482131\Blink.ino
Using board 'nano' from platform in folder: C:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5
Using core 'arduino' from platform in folder: C:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5
Detecting libraries used...
"C:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "C:\\Users\\rolfd\\AppData\\Local\\Temp\\arduino_build_603873\\sketch\\Blink.ino.cpp" -o nul
Generating function prototypes...
"C:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "C:\\Users\\rolfd\\AppData\\Local\\Temp\\arduino_build_603873\\sketch\\Blink.ino.cpp" -o "C:\\Users\\rolfd\\AppData\\Local\\Temp\\arduino_build_603873\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\rolfd\\AppData\\Local\\Temp\\arduino_build_603873\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Sketch wird kompiliert...
"C:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "C:\\Users\\rolfd\\AppData\\Local\\Temp\\arduino_build_603873\\sketch\\Blink.ino.cpp" -o "C:\\Users\\rolfd\\AppData\\Local\\Temp\\arduino_build_603873\\sketch\\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\rolfd\AppData\Local\Temp\arduino_cache_556491\core\core_arduino_avr_nano_cpu_atmega328_22a2c177abb4a693ac63dcc85cbfe6da.a
Linking everything together...
"C:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\rolfd\\AppData\\Local\\Temp\\arduino_build_603873/Blink.ino.elf" "C:\\Users\\rolfd\\AppData\\Local\\Temp\\arduino_build_603873\\sketch\\Blink.ino.cpp.o" "C:\\Users\\rolfd\\AppData\\Local\\Temp\\arduino_build_603873/..\\arduino_cache_556491\\core\\core_arduino_avr_nano_cpu_atmega328_22a2c177abb4a693ac63dcc85cbfe6da.a" "-LC:\\Users\\rolfd\\AppData\\Local\\Temp\\arduino_build_603873" -lm
"C:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\rolfd\\AppData\\Local\\Temp\\arduino_build_603873/Blink.ino.elf" "C:\\Users\\rolfd\\AppData\\Local\\Temp\\arduino_build_603873/Blink.ino.eep"
"C:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\rolfd\\AppData\\Local\\Temp\\arduino_build_603873/Blink.ino.elf" "C:\\Users\\rolfd\\AppData\\Local\\Temp\\arduino_build_603873/Blink.ino.hex"
"C:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\rolfd\\AppData\\Local\\Temp\\arduino_build_603873/Blink.ino.elf"
Der Sketch verwendet 934 Bytes (3%) des Programmspeicherplatzes. Das Maximum sind 30720 Bytes.
Globale Variablen verwenden 9 Bytes (0%) des dynamischen Speichers, 2039 Bytes für lokale Variablen verbleiben. Das Maximum sind 2048 Bytes.
C:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b115200 -D -Uflash:w:C:\Users\rolfd\AppData\Local\Temp\arduino_build_603873/Blink.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x20
avrdude done. Thank you.
Beim Hochladen des Sketches ist ein Fehler aufgetreten
If I use menu function upload with programmer, it works very well.
Thanks for help
