bug find? redclaration of int causes infinite loop...
#include <avr/wdt.h>
char in[101];
int x = 0;
   wdt_disable() ;
Serial3.begin(9600);
delay(10);
Serial.println(" Begin ");
Serial.flush();
  while (1 == 1){
  Serial.println(" Loop ");
  Serial.println(millis());
  Serial.flush();
  int x = 0;      // change this line to x = 0; and it works fine
  while (Serial3.peek() != '
The second line int x = 0; was wrongfully redeclared inside the loop. This causes an infinite reboot loop …
using latest ide (1.05)
  in = Serial3.read();
  x = x + 1;
  for (int i=0; i <= 100; i++){
      Serial.print(in[i]);
  Serial.flush();
      in[i] = 0;
  Serial.print(millis());
The second line int x = 0; was wrongfully redeclared inside the loop. This causes an infinite reboot loop ...
Not a bug in the programing language. Just a bug in your programming.
Local variables can have the same name as global variables. Your code will use the most local version of the variable.
johnwasser:
No program error should cause a "reboot loop." It sounds like a problem with the circuit.
also, instead of while (1 ==1) it makes more sense to say while(true)
WizenedEE:
A reboot is just the Arduino's reaction to most software crashes. It's easy to cause repeated crashes with bad code.
I would have expected the ide to pop up with an error message instead of crashing the atmega. :slight_smile:
Does that mean it should have worked then?
hotshotharry:
Looks good to me. The main problem I see is that you don’t have checks to prevent a long input rom overflowing the buffer. Try this:
char in[101];
int x = 0;
  wdt_disable() ;
  delay(10);
  Serial.flush();
  while (1 == 1) {
    Serial.flush();
      if (x < 100)  // Added to protect against buffer overflow.
      x = x + 1;
for (int i=0; i <= 100; i++) {
    Serial.flush();
      in[i] = 0;
// This code never executes:
hotshotharry:
The Arduino is a stand-alone computer. The IDE doesn’t have any way of knowing that your sketch crashed. You have to figure that out from the behavior of your sketch: typically you see a debug message you put into setup(). That means your sketch has re-started and that usually means your sketch has crashed. (And that usually means you used up al the SRAM.)
hotshotharry:
How would it be able to do that?
Or more precisely, how is the IDE supposed to tell the difference between your program which crashes (and therefore doesn't communication in any way) and a program that is running normally, but isn't supposed to communicate in any way?
