Bug in 0018 and 0017 - Ubuntu
When I try to type anything into the editor I get this exception:
BUG: getTextArea() returning null
Report this to Slava Pestov <sp@gjt.org>
Exception during event dispatch:
java.lang.NullPointerException
   at processing.app.syntax.InputHandler$insert_char.actionPerformed(InputHandler.java:1087)
   at processing.app.syntax.InputHandler.executeAction(InputHandler.java:281)
   at processing.app.syntax.DefaultInputHandler.keyTyped(DefaultInputHandler.java:286)
   at processing.app.syntax.JEditTextArea.processKeyEvent(JEditTextArea.java:1616)
   at java.awt.Component.processEvent(libgcj.so.10)
   at java.awt.Container.processEvent(libgcj.so.10)
   at java.awt.Component.dispatchEventImpl(libgcj.so.10)
   at java.awt.Container.dispatchEventImpl(libgcj.so.10)
   at java.awt.Component.dispatchEvent(libgcj.so.10)
   at java.awt.KeyboardFocusManager.redispatchEvent(libgcj.so.10)
   at java.awt.DefaultKeyboardFocusManager.dispatchKeyEvent(libgcj.so.10)
   at java.awt.DefaultKeyboardFocusManager.dispatchEvent(libgcj.so.10)
   at java.awt.Window.dispatchEventImpl(libgcj.so.10)
   at java.awt.EventQueue.dispatchEvent(libgcj.so.10)
   at java.awt.EventDispatchThread.run(libgcj.so.10)
I can't write anything, but most other stuff in the ide seem to work. I can paste stuff into the editor.
I'm running Ubuntu 9.10.
Install the sun-java6-jre package and activate it with
sudo update-alternatives --config java
Eberhard
That was easy enough :slight_smile:
Thanks!
