Hello,
I have just found a bug in one of the Chapter 3 files.
It is in the Motor_test_encoder.ino file and here it is:
//Chose the encoder to use:encoder1(default) or encoder2
Serial.print("Encoder1 Pos [counts]: ");
Serial.println(encoder2.getRawCount()); <--- BUG. Should be encoder1.getRawCount()
Serial.print("Encoder1 vel [counts/sec]: ");
Serial.println(encoder2.getCountPerSecond()); <--- BUG. Should be encoder1.getCountPerSecond()
As you can see, we believe we are going to publish what the value of Encoder # 1 is but we accidentally grab the value from Encoder # 2. In this chapter we have no motor on encoder # 2 so the user will not see data and wonder what is broken. Please help correct this in the master code file we give to the community.
Thanks!
