Hi All,
Nice little community you have here.
I'm having problems with reliability in a program that I have written. It will run fine for a while - anywhere from a couple hours to 19 hours almost to the tee. After that, sometimes it just freezes and sometimes it turns on pump1 indefinitely. Not sure what the problem is but I need a solution!
I'm fairly new to C and I'm hoping the problem is straight forward. Can you guys take a look at my code? Thanks!
//Initialize Global Variablles
//include libraries
#include <Wire.h>
#include <Time.h>
#include <TimeAlarms.h>
//define varibles
int i; //working variable
int co2_lower_limit = 1200; //parts per million
float dwell_start_up = 2; //seconds
float dwell_idle = 3; //seconds, time between samples
float dwell_co2_on = 1.25; //seonds
float dwell_co2_disperson = 30; //seconds
float dwell_pump1_on = 65;
float dwell_pump_trasition_delay = 10;
float dwell_pump2_on = 65;
int tempValue;
int pHValue;
//define outputs
int pump1 = 3;
int pump2 = 4;
int ACunit = 5;
int light = 6;
int co2_valve = 7;
int co2sensorpower = 8; // This is the default address of the CO2 sensor, 7bits shifted left.
// Address for co2 Meter
int co2Addr = 0x68;
//Run Setup
//setup pins- water, light, and temperature pins as outputs
pinMode(pump1, OUTPUT);
pinMode(pump2, OUTPUT);
pinMode(light, OUTPUT);
pinMode(ACunit, OUTPUT);
pinMode(co2_valve, OUTPUT);
//initial values of pins
digitalWrite (pump1, LOW);
digitalWrite (pump2, LOW);
digitalWrite(light, HIGH);
digitalWrite(ACunit, HIGH);
digitalWrite(co2_valve, LOW);
digitalWrite(13, LOW);
//set time
setTime(14,58,0,16,4,10); // set time to 8:29:40am Jan 1 2010
//would like to auto sync eventually
//setup light cycle times
Alarm.alarmRepeat(8,47,0, Daytime); // 6:30am daytime starts every day
//Alarm.alarmRepeat(2,00,0, Nighttime); // 12:30am nighttime starts every day
//setup water cycle times
Alarm.alarmRepeat(0,00,0, Water); // 8:00am water starts every day
Alarm.alarmRepeat(1,00,0, Water); // 8:00am water starts every day
Alarm.alarmRepeat(2,00,0, Water); // 8:00am water starts every day
Alarm.alarmRepeat(3,00,0, Water); // 8:00am water starts every day
Alarm.alarmRepeat(4,00,0, Water); // 8:00am water starts every day
Alarm.alarmRepeat(5,00,0, Water); // 8:00am water starts every day
Alarm.alarmRepeat(6,00,0, Water); // 8:00am water starts every day
Alarm.alarmRepeat(7,00,0, Water); // 8:00am water starts every day
Alarm.alarmRepeat(8,00,0, Water); // 8:00am water starts every day
Alarm.alarmRepeat(9,0,0, Water); // 10:00pm water starts every day
Alarm.alarmRepeat(10,0,0, Water); // 12:00pm water starts every day
Alarm.alarmRepeat(11,0,0, Water); // 2:00pm water starts every day
Alarm.alarmRepeat(12,0,0, Water); // 4:00pm water starts every day
Alarm.alarmRepeat(13,0,0, Water); // 6:00pm water starts every day
Alarm.alarmRepeat(14,0,0, Water); // 8:00pm water starts every day
Alarm.alarmRepeat(15,0,0, Water); // 10:00pm water starts every day
Alarm.alarmRepeat(16,0,0, Water); // 12:00pm water starts every day
Alarm.alarmRepeat(17,0,0, Water); // 2:00am water starts every day
Alarm.alarmRepeat(18,0,0, Water); // 2:00am water starts every day
Alarm.alarmRepeat(19,0,0, Water); // 2:00am water starts every day
Alarm.alarmRepeat(20,0,0, Water); // 2:00am water starts every day
Alarm.alarmRepeat(21,0,0, Water); // 2:00am water starts every day
Alarm.alarmRepeat(22,0,0, Water); // 2:00am water starts every day
Alarm.alarmRepeat(23,0,0, Water); // 2:00am water starts every day
Alarm.alarmRepeat(24,0,0, Water); // 2:00am water starts every day
//open serial port
Wire.begin ();
pinMode(13, OUTPUT); // We will use this pin as a read-indicator
Serial.println("What a wonderful day to grow tomatotoes!");
Serial.println("Initializing");
for (i = 0; i < dwell_start_up; i ++){
Serial.println(i);
Alarm.delay(1000);
//Run Loop
Serial.println("-------------------------------------");
//Display time
digitalClockDisplay();
if(light = 1){
Serial.println("(Daytime)");
else{
Serial.println("(Nighttime)");
//Print co2 value to serial
int co2Value = readCO2();
if(co2Value > 0) {
Serial.print("co2(ppm): ");
Serial.println(co2Value);
else {
Serial.println("checksum failed");
if(tempValue > 0) {
Serial.print("temp(F): ");
Serial.println(tempValue);
else {
if(pHValue > 0) {
Serial.print("pH: ");
Serial.println(pHValue);
else {
delay(dwell_idle * 1000); //second
//co2 valve logic
if (co2Value < co2_lower_limit && co2Value > 0) {
Serial.println("***low co2 value detected***");
Serial.print(co2Value);
Serial.print("(detected) < ");
Serial.print(co2_lower_limit);
Serial.println("(limit)");
Alarm.delay(500);// Solenoid dwell
Serial.print("co2 valve actuated for ");
digitalWrite(co2_valve, HIGH);
digitalWrite(13, HIGH);
Serial.print(dwell_co2_on);
Serial.println(" second(s)");
Alarm.delay((dwell_co2_on * 1000)); // Solenoid dwell, dwell_co2_on given in seconds
Serial.print("dispersion delay for ");
Serial.print(dwell_co2_disperson);
Alarm.delay(dwell_co2_disperson * 1000);// Delay dwell,dwell_co2_dispersion given in seconds
//if (co2Value > 1000);
//digitalWrite(co2_valve, LOW);
//digitalWrite(13, LOW);
Alarm.delay(1000);
// functions to be called when an alarm triggers:
void Daytime(){
Serial.print("Alarm: - Daytime");
void Nighttime(){
Serial.print("Alarm: - Nighttime");
digitalWrite(light, LOW);
digitalWrite(ACunit, LOW);
void Water(){
Serial.println("Time to Water");
//pump1
Serial.print("pump1 actuated for ");
Serial.println(dwell_pump1_on);
digitalWrite(pump1, HIGH);
Alarm.delay(dwell_pump1_on * 1000);
digitalWrite(pump1, LOW);
Alarm.delay(dwell_pump_trasition_delay * 1000);
//pump2
Serial.print("pump2 actuated for ");
Serial.println(dwell_pump2_on);
digitalWrite(pump2, HIGH);
Alarm.delay(dwell_pump2_on * 1000);
digitalWrite(pump2, LOW);
void digitalClockDisplay(){
// digital clock display of the time
Serial.print(hour());
printDigits(minute());
printDigits(second());
Serial.println(" ");
Serial.print(dayStr(weekday()));
Serial.print(" ");
Serial.print(day());
Serial.print(" ");
Serial.print(monthShortStr(month()));
Serial.print(" ");
Serial.print(year());
void printDigits(int digits){
// utility function for digital clock display: prints preceding colon and leading 0
Serial.print(":");
if(digits < 10)
Serial.print('0');
Serial.print(digits);
// Function : int readCO2()
// Returns : CO2 Value upon success, 0 upon checksum failure
// Assumes : - Wire library has been imported successfully.
// - LED is connected to IO pin 13
// - CO2 sensor address is defined in co2_addr
int readCO2() {
int co2_value = 0; // We will store the CO2 value inside this variable.
/* Begin Write Sequence */
Wire.beginTransmission(co2Addr);
Wire.send(0x22);
Wire.send(0x00);
Wire.send(0x08);
Wire.send(0x2A);
Wire.endTransmission();
/* End Write Sequence. */
We wait 10ms for the sensor to process our command.
The sensors's primary duties are to accurately
measure CO2 values. Waiting 10ms will ensure the
data is properly written to RAM
Alarm.delay(10);
/* Begin Read Sequence */
Since we requested 2 bytes from the sensor we must
read in 4 bytes. This includes the payload, checksum,
and command status byte.
Wire.requestFrom(co2Addr, 4);
byte i = 0;
byte buffer[4] = {0, 0, 0, 0};
Wire.available() is not nessessary. Implementation is obscure but we leave
it in here for portability and to future proof our code
while(Wire.available()) {
buffer[i] = Wire.receive();
i++;
/* End Read Sequence */
Using some bitwise manipulation we will shift our buffer
into an integer for general consumption
co2_value = 0;
co2_value |= buffer[1] & 0xFF;
co2_value = co2_value << 8;
co2_value |= buffer[2] & 0xFF;
byte sum = 0; //Checksum Byte
sum = buffer[0] + buffer[1] + buffer[2]; //Byte addition utilizes overflow
if(sum == buffer[3]) {
// Success!
return co2_value;
else {
return 0;
