Bug in Keypad library
In the Keypad library, which is distributed with the IDE, there is a bug in initializePins which currently looks like this:
void Keypad::initializePins(){
  for (byte r=0; r<size.rows; r++){
    for (byte c=0; c<size.columns; c++){
      pinMode(columnPins[c],OUTPUT);
      digitalWrite(columnPins[c],HIGH);
    //configure row pin modes and states
    pinMode(rowPins[r],INPUT);
    digitalWrite(rowPins[r],HIGH);
Notice that if you have a 4x4 keypad the inner loop which does this:
… is done 16 times, which is unnecessary. This should be rewritten as:
    //configure column pin modes and states
Then when I was investigating another problem I noticed this in Keypad.h:
typedef struct {
    byte rows : 4;
    byte columns : 4;
} KeypadSize;
When I saw that code I felt a great disturbance in the Force. Hmmm … I haven’t seen code like that for …
The declaration “rows : 4” means "allocate 4 bits for rows (ditto for columns).
Now on the face of it, this might seem like a clever way to save one byte (since rows/columns now take one byte rather than two).
However compiling a test program (below) shows that this actually uses an extra 68 bytes rather than saving one!
Using the original library, the sketch below takes 1826 bytes. Then by making a copy of the library and removing the “: 4” from the declarations, the sketch size drops to 1758 bytes. That is 68 bytes less.
So if the library was amended to remove the two lots of “: 4” from Keypad.h, everyone’s sketches would be smaller, not larger.
 #include <Keypad.h>
  const byte ROWS = 4; //four rows
  const byte COLS = 3; //three columns
  char keys[ROWS][COLS] = {
    {'1', '2', '3'},
    {'4', '5', '6'},
    {'7', '8', '9'},
    {'A', 'B', 'C'},
  byte rowPins[ROWS] = {5, 10, 9, 7}; //connect to the row pinouts of the keypad
  byte colPins[COLS] = {6, 4, 8}; //connect to the column pinouts of the keypad
  // Create the Keypad
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup ()
 byte key =  kpd.getKey();
void loop () {}
I am guessing the reason for this is that, whilst the structure might be slightly smaller, the code generated to extract out the 4-bit fields is somewhat larger.
Hi Nick,
I have encountered errors while programming which is the programming line below highlighted in red, the keypad defining kpd, the program cannot read it as a type. I am using a Waspmote board instead of arduino. I placed the keypad.cpp and keypad.h file in the library and followed your instructions to rewrite the keypad library, the program manages to read the 'Keypad' defining the kpd as the colour of the 'keypad' changes. However, the error still persists. The error states : "Keypad does not name a type in function void loop()".
The following is my code:
const byte ROWS = 4; //four rows const byte COLS = 3; //three columns char keys[ROWS][COLS] = { {'1','2','3'}, {'4','5','6'}, {'7','8','9'}, {'#','0','*'} }; byte rowPins[ROWS] = {5, 4, 3, 2}; //connect to the row pinouts of the keypad byte colPins[COLS] = {8, 7, 6}; //connect to the column pinouts of the keypad
void setup(){ USB.begin(); }
void loop(){ byte key = kpd.getKey();
if (key != NO_KEY){ USB.println(key); } }
Please advice Thanks in advance.
Did you do this?
 #include <Keypad.h>
It is only when i exclude Keypad.h, i will have the error stated above.
If i include Keypad.h, i will have more complex errors as in the picture in the link: http://i1131.photobucket.com/albums/m542/couchpotato8/error.png
Regards.
You don’t need to post screenshots of error messages you know. You can just copy and paste them which is a lot more readable.
Is that the whole sketch? There is no USB defined anywhere. If I change USB to Serial, this compiles for me without errors:
#include <Keypad.h>
  {'1','2','3'},
  {'4','5','6'},
  {'7','8','9'},
  {'#','0','*'}
void setup(){
void loop(){
  if (key != NO_KEY){
    Serial.println(key);
I used the code you posted and i am still getting the same results, is it because i am using the waspmote IDE instead of Arduino or do i need to add anything else into my library?
Regrads.
I am not familiar with the waspmote IDE, so I can't say what else you have to do. My test was under the Arduino IDE.
