bug in liquidCrystalDisplay Class ?
The setcursor command of the LiquidCrystal library contains a bug ( IDE22 , windows 7)
void LiquidCrystal::setCursor(uint8_t col, uint8_t row)
  int row_offsets[] = { 0x00, 0x40, 0x14, 0x54 };
  if ( row > _numlines ) {                                                <<<<<<<<<<<<
    row = _numlines-1;    // we count rows starting w/0
  command(LCD_SETDDRAMADDR | (col + row_offsets[row]));
It should be -- if (row >= _numLines) --
as when you define lcd.begin(20,4); _numLines will be 4.
If you do setCursor(x,4), row will be 4; the if test will fail and command will access row_offsets[4] which is not defined ... eh outside the array...
Please confirm, (or is it only my version of the LCD lib?)
Good eyes. How did you find this bug?
Handtracing the code for rows = 4 ! - I was searching for the cause of a bug in another thread today with an 20x4 display.
