Hello Forum,
I have developed a code to read an image stored on my SD Card and display it on a TFT. I can read the image from the SD Card successfully but I cannot draw it on the TFT. I dunno where is the bug.
Could you please guys help me figure it out?
Board: Arduino DUE
#include <Arduino.h>
#include <SPI.h>
#include <SD.h>
#include <string.h>
#include "ascii_data.h"
#define SERIAL_PORT 9600
#define PIN_SCE 10
#define PIN_RESET 6
#define PIN_DC 5
// #define PIN_SDIN
// #define PIN_SCLK
#define PIN_LED 2
#define LCD_COMMAND LOW
#define LCD_DATA HIGH
#define CHAR_WIDTH 6
#define CHAR_HEIGHT 8
#define LCD_WIDTH 84
#define LCD_HEIGHT 48
#define CHARS_PER_ROW (LCD_WIDTH / CHAR_WIDTH)
#define CHARS_PER_COL (LCD_HEIGHT / CHAR_HEIGHT)
#define PIN_SCSD 4
void draw();
void reset();
void cls();
void lcdMode(int mode);
void lcdInitialize();
void printString(int y, const char *value);
void printString(int x, int y, const char *value);
int printChar(int x, int y, char value);
void setPixel(int x, int y, int value);
void lcdWrite(int value);
byte data[84][6] = {0};
String input = "";
bool complete = false;
// Enable I/O stream
Serial.begin(SERIAL_PORT);
Serial.println("Serial Init..");
// pin modes
pinMode(PIN_SCE, OUTPUT);
pinMode(PIN_RESET, OUTPUT);
pinMode(PIN_DC, OUTPUT);
pinMode(PIN_LED, OUTPUT);
pinMode(PIN_SCSD, OUTPUT);
// SD stuff
SD.begin(PIN_SCSD);
// display stuff
reset();
SPI.begin(PIN_SCE);
SPI.setClockDivider(PIN_SCE, SPI_CLOCK_DIV16);
lcdInitialize();
input.reserve(200);
printChar(0, 0, 'a');
while (Serial.available() > 0) {
char ch = (char)Serial.read();
//Serial.print(ch);
if (isprint(ch) && ch != '\n') {
input += ch;
//Serial.println(input);
else {
complete = true;
if (complete) {
Serial.print("Command: ");
//Serial.println(input.startsWith("exists(") && input.endsWith(")"));
if (input.startsWith("exists(") && input.endsWith(")")) {
String file = input.substring(7, input.length() - 1);
Serial.print("File: ");
Serial.println(file);
File f = SD.open(file);
if (f) {
Serial.println("File does exists");
f.close();
Serial.println("File does not exist");
} else if (input.startsWith("print(") && input.endsWith(".img)")) {
String file = input.substring(6, input.length() - 1);
if (f) {
cls();
Serial.print("Printing image: ");
// Dimensionen auslesen
int width = 0;
int height = 0;
char ch = '\0';
String dim = "";
while (f.available()) {
ch = (char)f.read();
if (ch != ',' && ch != '\n')
dim += ch;
else {
if (width == 0) {
width = dim.toInt();
dim = "";
} else if (height == 0) {
height = dim.toInt();
if (ch == '\n') {
Serial.print("Dimensions of image: ");
Serial.print(width);
Serial.print(" x ");
Serial.println(height);
for (int i = 0; i < height; ++i) {
for (int x = 0; x < width; ++x){
char ch = '\0';
while (ch != '\n') {
ch = f.read();
if (ch == ','){
continue;
}else (ch == '0' || ch == '1') {
int pix = ch - '0';
setPixel(x, i, pix);
} else if (input.startsWith("print(") && input.endsWith(")")) {
if (f) {
cls();
int x = 0;
int y = 0;
Serial.print("Printing: ");
char ch = (char)f.read();
Serial.print(ch);
if (-1 == printChar(x, y, ch));
draw();
x = (x + 6) % 84;
if (x == 0) {
y = (y + 8) % 48;
Serial.println("Error: File does not exist");
Serial.println("Unknown command");
complete = false;
input = "";
draw();
delay(10);
void draw()
lcdMode(LCD_DATA);
for (int b = 0; b < 6; ++b) {
for (int x = 0; x < 84; ++x) {
lcdWrite(data[x][b]);
void reset()
digitalWrite(PIN_RESET, LOW);
digitalWrite(PIN_RESET, HIGH);
void cls()
for (int x = 0; x < LCD_WIDTH; ++x) {
for (int y = 0; y < LCD_HEIGHT; ++y) {
setPixel(x, y, 0);
digitalWrite(PIN_DC, mode);
lcdMode(LCD_COMMAND);
// FUNCTION SET (extended instruction set)
lcdWrite(0x21);
// SET BIAS
lcdWrite(0x14);
// SET TEMP COEFFICIENT
lcdWrite(0x04);
// SET CONTRAST
lcdWrite(0xBF);
// FUNCTION SET (normal instruction set)
lcdWrite(0x20);
// SET DISPLAY MODE (normal)
lcdWrite(0x0C);
// reset display
lcdWrite(0x40);
lcdWrite(0x80);
printString((84 - strlen(value) * 6) / 2, y, value);
do
printChar(x, y, *value);
x += 6;
} while (*++value != '\0');
lcdMode(LCD_DATA);
if (value < ' ') {
return -1;
for (int dx = 0; dx < 6; ++dx) {
for (int dy = 0; dy < 8; ++dy) {
setPixel(x + dx, y + dy, !!(font[value - ' '][dx] & (1 << dy)));
return 0;
if (x >= 0 && x < 84 && y >= 0 && y < 48) {
if (value) {
data[x][y / 8] |= (1 << (y % 8));
data[x][y / 8] &= ~(1 << (y % 8));
digitalWrite(PIN_SCE, LOW);
SPI.transfer(PIN_SCE, value, SPI_CONTINUE);
digitalWrite(PIN_SCE, HIGH);
Image_from_SD.zip (3.17 KB)
