BUG: Unable to upload compiled sketch if contains !!!
If I compile and upload small some sketch, it is all ok. It is uploaded and running.
avrdude: verifying ...
avrdude: 14948 bytes of flash verified
But bigger another sketch uploading ends with timeout:
avrdude: Recv: . [03]
*** dump is too big - I cut them ***
         Hardware Version: 15
         Firmware Version Master : 2.10
         Vtarget         : 0.0 V
         SCK period      : 111.8 us
avrdude: AVR device initialized and ready to accept instructions
################################## | 100% 0.02s
avrdude: reading input file "C:\Users\ADMINI~1\AppData\Local\Temp\build5648009842651918152.tmp\Mega2560_sketch_for_1_0_5.cpp.hex"
avrdude: writing flash (25768 bytes):
Writing | avrdude: Send: . [1b] . [0e] . [00] . [05] . [0e] . [06] . [80] . [00] . [00] . [00] . [98]
avrdude: Recv: . [1b]
avrdude: Recv: ! [21]
avrdude: Recv: . [0d]
avrdude: Recv: . [0a]
avrdude: Recv: A [41]
avrdude: Recv: r [72]
avrdude: Recv: d [64]
avrdude: Recv: u [75]
avrdude: Recv: i [69]
avrdude: Recv: n [6e]
avrdude: Recv: o [6f]
avrdude: Recv:   [20]
avrdude: Recv: e [65]
avrdude: Recv: x [78]
avrdude: Recv: p [70]
avrdude: Recv: l [6c]
avrdude: Recv:   [20]
avrdude: Recv: s [73]
avrdude: Recv: t [74]
avrdude: Recv: k [6b]
avrdude: Recv: 5 [35]
avrdude: Recv: 0 [30]
avrdude: Recv: V [56]
avrdude: Recv: 2 [32]
avrdude: Recv:   [20]
avrdude: Recv: b [62]
avrdude: Recv: y [79]
avrdude: Recv:   [20]
avrdude: Recv: M [4d]
avrdude: Recv: L [4c]
avrdude: Recv: S [53]
avrdude: Recv: B [42]
avrdude: Recv: a [61]
avrdude: Recv: > [3e]
avrdude: Recv: H [48]
avrdude: Recv: h [68]
avrdude: Recv: ? [3f]
At the end is evident bootloader prompt - I don’t know what is mean.
(I try IDE 1.0.5 and 1.5.4 - same result, I try different boards - same result)
I discovered the cause. I changed glcdfont.c file. It contains a different character set. but Binary size is the same as original! Compiling reports no errors, the file is probably OK. But the upload does not work.
glcdfont.c_original (7.95 KB)
glcdfont.c_latin2 (13.3 KB)
So, by comparing files I found source of problem:
0x21, 0x21, 0x21
this causes stuck! If anywhere in the program there are this sequence, upload always crashes! Try modified blink example:
  Blink
  Turns on an LED on for one second, then off for one second, repeatedly.
  This example code is in the public domain.
// Pin 13 has an LED connected on most Arduino boards.
// give it a name:
int led = 13;
  char xxx[] = {0x00, 0x21, 0x21, 0x21, 0x00};
// the setup routine runs once when you press reset:
  // initialize the digital pin as an output.
  pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
  digitalWrite(led, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(xxx[1]);               // wait for a second
  digitalWrite(led, LOW);    // turn the LED off by making the voltage LOW
  delay(xxx[2]);               // wait for a second
It's not a bug. Three exclamation marks anywhere in your sketch puts the processor into a different mode. It's been discussed many times so if you do a search you should be able to find out more information - if you want to!
Thanks for reply. Searching for !!! gives no results. When searching for 'three/triple exclamation marks', I also did not find "Yes, it is so intentionally". Can you direct me to the right site?
https://code.google.com/p/arduino/issues/detail?id=392
Thanks, in the speed I looked at many search results and found this explanation:
http://www.avr-developers.com/bootloaderdocs/index.html
It is sad that this webpage is not referenced in the description of the products (bootloader is mentioned, but not this feature)
