Bug with Serial.print in the new arduino 1.0
The code below does not work the same on the new arduino 1.0 as with the old software. It should continously print longer and longer strings of ones (1111…)
BUT when adding four digits every time it just prints the following:
111111
2111111111
31111111111111
411111111111111111
5 1111111111111111111
It does however work when adding both three and five ones every time (111)(11111).
I have no explanation but it does represent a huge problem to the code i need to write.
For now I will just go back using the old software, but I guess this can be fixed for v1.1
Wasn’t sure who to let know, but now somebody knows at least :slight_smile:
int cnt=0;
String longstring=“1”;
Serial.begin(9600);}
cnt=cnt+1;
String add=“1111”;
Serial.print(String(cnt));
longstring=longstring+add;
Serial.println(longstring);
Are you saying that if you add 4 characters at a time it stops at 5 iterations and that if you add 3 or 5 it goes on forever?
bug confirmed
code works under 0.22 (up to cnt = 98 and then the longstring resets and continues ) and code stops under 1.0 after cnt = 5
int cnt=0;
String longstring="1";
  Serial.begin(115200);  // to speed up the test a bit
  cnt=cnt+1;
  String add="1111";
IDE 1.0: 3 & 5 sketch does run until 99 and then locks..
int cnt=0;
  cnt=cnt+1;
  String add3="111";
  String add5="11111";
  if (cnt %2 ==0) longstring=longstring+add3;
  else longstring=longstring+add5;
Should report the bug - http://code.google.com/p/arduino/issues/list -
advice : don't use strings...
Do you have access to a Teensy board? Teensyduino has the original String implementation I tried to contribute to Arduino.
I just ran this and it seems to work fine. It continues printing forever **, but the string stops getting longer after 162 because available memory has run out.
** ok, forever is still running after a few minutes... but Teensy sends at full USB speed, not 9600 baud. After only the time I've written this message, it's hit 16 bit numerical overflow and is now printing negative numbers on the beginning of each line! Oh, now it's rolled back over to positive...
