Buienradar
Hallo allemaal.
Ik had het idee om de temperatuur windsnelheid etc. Op een lcd te tonen. Ik vond een soort gelijke code die het deed met google weather maar die werkt niet meer. Ik ben nog niet erg ervaren, dus kan iemand mij hier mee helpen.
ik had de xml link gevonden op http://gratisweerdata.buienradar.nl/
 * Based on SimpleClientGoogleWeatherDHCP - This one comes with High Temp and Current conditions data.
 * gets xml data from http://www.google.com/ig/api?weather=milwaukee,wi
 * reads temperature from field:  <temp_f data="66" />
 * writes temperature  to 20x4 LCD. Using Ardiuno Mega 2640
#if ARDUINO > 18
#include <SPI.h>         // needed for Arduino versions later than 0018
#endif
#include <Ethernet.h>
#include <TextFinder.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(8, 7, 6, 5, 4, 3, 2);
//LCD Pinout is: PIN 1 is VSS TO GND, PIN 2 is VDD 5v, PIN 3 is V0 TO GRN) PIN 4 is RS, PIN5 is RW, PIN6 is E, DB Pins 4 thru 14 (PINS 7 - 10 (DB 0 - DB 3 OPEN) Pin 15 backlight
//16 backlight ground
int backLight = 1;    // pin 28 will control the backlight
byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x8F, 0xD3 };
byte ip[] = { 192, 168, 178, 1 };
byte server[] = {
  217,118,167,200 }; // Google
EthernetClient client;
TextFinder  finder( client );
char cond[40];
char fcond[40];
char wind[25];
int forelow1;
int forehigh1;
  pinMode(backLight, OUTPUT);
  digitalWrite(backLight, HIGH); // turn backlight on. Replace 'HIGH' with 'LOW' to turn it off.
  lcd.begin(20,4);
  lcd.setCursor(0,0);
  lcd.print("I'm alive");
  Ethernet.begin(mac, ip);
  if (client.connect(server, 80)) {
    client.println("GET http://www.buienradar.nl/weerstation/6290/Meetstation Twente");
    client.println();
  else {
    lcd.println("Can not connect ");
  if (client.connected()) {
    finder.find("<condition data");
    finder.getString("=","/",cond,(40));
    finder.find("<luchtvochtigheid>");
    int temperature = finder.getValue();
    finder.find("<windsnelheidBF>");
    finder.getString(":","/",wind,(40));
    finder.find("<low data=");
    forelow1 = finder.getValue();
    finder.find("<high data=");
    forehigh1 = finder.getValue();
    finder.getString("=","/",fcond,(40));
    //Print this
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("Currently:");
    lcd.setCursor(0,1);
    lcd.print("Temperature = ");
    lcd.print(temperature);
    lcd.setCursor(0,2);
    lcd.print("Wind:");
    lcd.print(wind);
    lcd.setCursor(0,3);
    lcd.print(cond);
    delay(4000);
    lcd.clear();
    lcd.print("Tomorrow: ");
    lcd.setCursor(0,1);
    lcd.print("Expected Low: ");
    lcd.print(forelow1);
    lcd.setCursor(0,2);
    lcd.print("Expected High: ");
    lcd.print(forehigh1);
    lcd.setCursor(0,3);
    lcd.print(fcond);
    delay(4000);
  else {
    lcd.clear();
    lcd.print("Can not find xml tag");
  client.stop();
  client.flush();
  delay(4000); // wait a minute before next update
“Doet het niet” is niet duidelijk genoeg.
Wat gaat er mis ?
Ik weet niet hoe je de gegevens: temperatuur luchtvochtigheid etc. uit de xml haalt.
Google is je beste vriend
Hij werkt nu bijna…
ik gebruik nu de api van http://weather.yahooapis.com/forecastrss?w=729139&u=c
het einige waar ik niet uitkom is om de “<yweather:condition text=” op het scherm te krijgen. Wat doe ik fout?
alvast bedankt.
#include <SPI.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xAD };
byte ip[] = { 192, 168, 178, 15 };
byte gateway[] = { 192, 168, 178, 1 };
byte subnet[] = { 255, 255, 255, 0 };
// Server Yahoo
IPAddress server(66,196,66,157);
int backLight = 1;
char place[50];
char hum[30];
char cond[40];
  lcd.begin(20,4);
  // Start Ehternet
  // Start Serial Port
  Serial.println("Setup...");
  lcd.setCursor(0,0);
  lcd.print("Opstarten...");
  delay(3000);
  lcd.clear();
    Serial.println("Connect to Yahoo Weather...");
    lcd.setCursor(0,0);
    lcd.print("Weer gegevens laden...");
    client.println("GET http://weather.yahooapis.com/forecastrss?w=729139&u=c");
    client.println();
    Serial.println("Connected...");
    lcd.setCursor(0,1);
    lcd.print("Gelukt!");
    lcd.clear();
    Serial.println(" connection failed");
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("Geen verbinding");
    lcd.setCursor(0,3);
    lcd.print("ERROR code 0001");
    // Humidity
   if ( (finder.getString("<yweather:atmosphere humidity=\"", "\"",hum,40)!=0) )
     Serial.print("Humidity:  ");
     Serial.println(hum);
     Serial.print("%");
     lcd.setCursor(0,1);
     lcd.print("vochtigheid:  ");
     lcd.print(hum);
     lcd.print(" %");
     Serial.print("No Humidity Data");
     lcd.setCursor(0,0);
     lcd.print("Geen Vochtigheid");
     lcd.setCursor(0,1);
     lcd.print("iformatie gevonden");
     lcd.setCursor(0,3);
     lcd.print("ERROR code 0002");
    // Place/City
    if ( (finder.getString("<title>Conditions for ", " ",place,50)!=0) )
      Serial.print("City:  ");
      Serial.println(place);
      lcd.setCursor(0,0);
      lcd.print("Plaats:  ");
      lcd.setCursor(0,0);
      lcd.print(place);
      lcd.setCursor(0,0);
     lcd.print("Geen plaats gevonden");
     lcd.setCursor(0,3);
     lcd.print("ERROR code 0003");
    // Temperature
    if(finder.find("temp=") )
     Serial.print("Temp C:  ");
     Serial.println(temperature);
     lcd.setCursor(0,2);
     lcd.print("Temperatuur:  ");
     lcd.print(" C");
     Serial.print("No Temperature Data");
     lcd.setCursor(0,0);
     lcd.print("Geen temperatuur");
     lcd.setCursor(0,1);
     lcd.setCursor(0,3);
     lcd.print("ERROR code 0004");
   if(finder.find("<yweather:condition text=")) {
     lcd.setCursor(0,3);
     lcd.print(cond);
   else {
     lcd.setCursor(0,3);
     lcd.print("geen conditie");
  // END XML
    Serial.println("Disconnected");
    lcd.setCursor(0,0);
    lcd.print("Disconnected");
  client.stop();
  client.flush();
  delay(60000);
Je bent zeer vaag in je foutomschrijvingen…
Krijg je iets anders? Krijg je een foutmelding?
Kan je een scherm afdruk geven, via de monitor?
Waar heb je deze sketch gehaald, komt ook bij mij op?
Een duidelijke vraag helpt om het probleem te definiëren.
