I have done a lot of reading, experimenting, and still can not figure out how to make a DC millivolt meter from an Arduino. I have no problem with the whole number voltages, but the millivolt voltages are a problem. I understand the concept of a voltage divider circuit and know how to calculate resistors. But for the millivolt range, one resistor always comes out as a negative resistance.
Is there somebody that can give me direction ?
Thanks in advance.
Kurt
The analogReference() can be set to 1.1V for an Arduino Uno. With 10 bits, and 1024 steps, that is about 1mV per step. If you need more, then you need a amplifier with a certain gain.
You have to tune the calculation in the sketch or measure AREF for the exact value of the 1.1V, since it is never exactly 1.100V.
To measure millivolts, use a protection resistor. For example 1k or 4k7 to the analog input.
If you want to measure the voltage accurate, then an accurate external voltage reference is needed.
A voltage divider lowers the voltage. For example if you want to measure a 12V battery.
The [u]Read Analog Voltage Example[/u] will give you readings up to 5V with resolution of about 5mV.
If you simply switch to the [u]1.1V Internal Reference[/u] and adjust the voltage calculation formula accordingly, you'll get about 1mV resolution (and you can read up to 1.1V).
And of course if you want to display millivolts, multiply by 1000.
Thank you for the quick response and direction. That gives me something to work with. Again......thanks
