SurferTim:
And what about html5? Besides the Arduino, I have an HTML5 server, and I am not getting your gyro data either.
It appears the iPad uses a client JavaScript/CSS API to access the gyro data. That should not be a problem. Send it the JavaScript API code and you should be good to go.
edit: Here is server code that shows how to embed JavaScript in your html doc.
Arduino Playground - HomePage
hello
now, I can get the gyro data, it will appear on my browser,
here is my arduino code:
Program: eth_websrv_SD
Description: Arduino web server that serves up a basic web
page. The web page is stored on the SD card.
Hardware: Arduino Uno and official Arduino Ethernet
shield. Should work with other Arduinos and
compatible Ethernet shields.
2Gb micro SD card formatted FAT16
Software: Developed using Arduino 1.0.3 software
Should be compatible with Arduino 1.0 +
SD card contains web page called index.htm
References: - WebServer example by David A. Mellis and
modified by Tom Igoe
- SD card examples by David A. Mellis and
Tom Igoe
- Ethernet library documentation:
http://arduino.cc/en/Reference/Ethernet
- SD Card library documentation:
http://arduino.cc/en/Reference/SD
Date: 10 January 2013
Author: W.A. Smith, http://startingelectronics.com
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
// MAC address from Ethernet shield sticker under board
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168, 1, 177); // IP address, may need to change depending on network
EthernetServer server(80); // create a server at port 80
String HTTP_req; // stores the HTTP request
File webFile;
Ethernet.begin(mac, ip); // initialize Ethernet device
server.begin(); // start to listen for clients
Serial.begin(115200); // for debugging
// initialize SD card
Serial.println("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("ERROR - SD card initialization failed!");
return; // init failed
Serial.println("SUCCESS - SD card initialized.");
// check for index.htm file
if (!SD.exists("index.htm")) {
Serial.println("ERROR - Can't find index.htm file!");
return; // can't find index file
Serial.println("SUCCESS - Found index.htm file.");
EthernetClient client = server.available(); // try to get client
if (client) { // got client?
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) { // client data available to read
char c = client.read(); // read 1 byte (character) from client
HTTP_req += c; // save the HTTP request 1 char at a time
// last line of client request is blank and ends with \n
// respond to client only after last line received
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connection: close");
client.println();
// send web page
webFile = SD.open("index4.htm"); // open web page file
if (webFile) {
while(webFile.available()) {
client.write(webFile.read()); // send web page to client
webFile.close();
// display received HTTP request on serial port
Serial.print(HTTP_req);
HTTP_req = ""; // finished with request, empty string
// every line of text received from the client ends with \r\n
if (c == '\n') {
// last character on line of received text
// starting new line with next character read
else if (c != '\r') {
// a text character was received from client
currentLineIsBlank = false;
} // end if (client.available())
} // end while (client.connected())
delay(1); // give the web browser time to receive the data
client.stop(); // close the connection
} // end if (client)
here is the html5 code
Peter Friese's Gyro Demo
#no {
display: none;
@media screen {
html, body, div, span {
margin: 0;
padding: 0;
border: 0;
outline: 0;
font-size: 100%;
vertical-align: baseline;
body {
height: auto;
-webkit-text-size-adjust:none;
font-family:Helvetica, Arial, Verdana, sans-serif;
padding:0px;
overflow-x: hidden;
.outer {
background: rgba(123, 256, 245, 0.9);
padding: 0px;
min-height: 48px;
.box {
position: relative;
float: left;
width: 45%;
padding: 7px;
border: 1px solid rgba(255, 255, 255, 0.6);
background: rgba(178,215,255,0.75);
min-height: 160px;
.box2 {
position: relative;
float: left;
width: 45%;
padding: 7px;
.box span {
display: block;
span.head {
font-weight: bold;
Your browser does not support Device Orientation and Motion API. Try this sample with iPhone, iPod or iPad with iOS 4.2+.
Arduino AJAX Switch Status
Switch state: Not requested...
the gyro data will show on my browser.but I can not pass this data to my arduino to use it quite unhappy~~
