I'm new to Arduino. I have to build a temperature monitor by using
•Shift Register.
•A 2-digit LED(LDD-HTF304NI).http://datasheet.octopart.com/LDD-HTF304NI-Lumex-datasheet-13230160.pdf
•Two buttons.
•Temperature sensor.
The behaviour of the system should be:
In the default state, the temperature is displayed on the display.
When button 1 is pressed: the system records ten temperatures at one-second intervals, with some form of indication to show that it is gathering data. When data collection ends, the system should return to the default state, and give some form of indication that it has done so. The temperatures recorded should be stored for later use.
When button 2 is pressed, either:
If there are stored temperatures in memory, the system displays them.
If there are no stored temperatures in memory, the system indicates this.
Can someone give me some advice about the code, please?
