Build folder disappeared or could not be written in Windows XP!
Hello, I am using Arduino 1.0, and very newbie in microcontroller.
When I open the File → Examples → Digital → BlinkWithoutDelay then I just compile it,
then It appears some strange looks something goes wrong, it appears:
java.io.FileNotFoundException: H:\arduino-1.0\build_folder\BlinkWithoutDelay.cpp (the system cannot find the path specified)
at java.io.FileOutputStream.open(Native Method)
at.java.io.FileOutputStream.<init>(FileOutputStream.java:179)
at.java.io.FileOutputStream.<init>(FileOutputStream.java:131)
at processing.app.preproc.pdePreprocessor.writePrefix(PdePreprocessor.java:139)
at processing.app.Sketch.preprocess(Sketch.java:1277)
at processing.app.Sketch.preprocess(Sketch.java:1229)
at processing.app.Sketch.build(Sketch.java:1510)
at processing.app.Sketch.build(Sketch.java:1493)
at processing.app.Editor$DefaultRunHandler.run(Editor.java:1833)
...etc
I have searched in the troubleshooting guide, but it only gives for MAC only.
The errors are so strange, I do not even have local disk H: for my notebook/
Please anyone can help me through?
Thank you all!
I’m also having a problem. It’s been working fine for months, but now it isn’t working!
Here’s the error message:
java.io.FileNotFoundException: C:\Users\MyName\AppData\Local\Temp\build1566705018473219673.tmp\Trying_to_program_Remote_Control_TEAC_1.cpp (The system cannot find the path specified)
	at java.io.FileOutputStream.<init>(FileOutputStream.java:179)
	at java.io.FileOutputStream.<init>(FileOutputStream.java:131)
	at processing.app.preproc.PdePreprocessor.writePrefix(PdePreprocessor.java:139)
	at processing.app.Sketch.preprocess(Sketch.java:1387)
	at processing.app.Sketch.preprocess(Sketch.java:1339)
	at processing.app.Sketch.build(Sketch.java:1620)
	at processing.app.Sketch.exportApplet(Sketch.java:1648)
	at processing.app.Sketch.exportApplet(Sketch.java:1634)
	at processing.app.Editor$DefaultExportHandler.run(Editor.java:2346)
	at java.lang.Thread.run(Thread.java:619)
processing.app.debug.RunnerException: Build folder disappeared or could not be written
	at processing.app.Sketch.preprocess(Sketch.java:1394)
What’s wrong? I browsed for the folder and the folder AppData wasn’t there!
Any solutions?
I found appData by typing %TEMP% in the windows explorer. But the build files aren't there!
It's working fine now. I restarted the program and nothing is wrong. If this ever happens to anyone, they should just restart it and see if that fixed it. :)
If this ever happens to anyone, they should just restart it...
The classic and time-proven way to fix a computer problem :)
Rob
