Making a sine wave generator using my Arduino Uno. Building a Chebyshef Low Pass. Came across this schematic for it. What is the component at the right side labeled 100K?
Thanks!
Thanks!
100K Ohm potentiometer, probably for output level control (volume).
aharasewych:
A potentiometer, setting output amplitude. Note that the response of the filter varies by load, so it's built with a low impedance load, and then provides a high impedance output. A better isolation would be an op amp, but if you're adding that, you might as well be building an active filter with steeper cut-off.
Btw, if that's an anti-aliasing / reconstruction filter for something like a square wave input, a 12 kHz corner frequency means a 24 kHz overtone will only be at -15 dB below unity. It won't be close to a real sine wave.
Yes it is a very poor filter design.
Is the sin wave frequency fixed?
If not it will not be a good sin wave at lower frequencies.
Well, found a lab for it online and this is how they had it pictured. So long as i can get a sun wave to show up, ill be fine - doesn't have to be perfect.
http://interface.khm.de/index.php/lab/experiments/arduino-dds-sinewave-generator/
More about learning how it works. but thank you. However, if you know of another method/filter that can be put together quickly and frugally, let me know!
I think you mean Sin.
OK fine, as long as you remember it will give you a very low output signal, and just like that link not very much of a Sin wave.
Hmm... The two 270 ohms resistors... they make me feel unconfortable. A bit low and using an Arduino output to them. That is the part that I am not comfortable with.
Did you have a simulator you can use ? It may help you.
