Building a car
In my current project I am trying to build a car. I have multiple questions regarding this project.
  1. How should I mount my Arduino onto the car
  2. What material should I mount the Arduino on
  3. What type of motor would be best for making the wheels and how much current/voltage will it need
Use whatever you like ... and what you can work with. Plywood is a classic, easy to work with. You can build anything with thm, even the wheels. Or you can go to a to store and by a car of the dimension and design you like. That's probably the easiest way to go.
Thanks for the answer. The car will use a ultrasonic distance sensor; the HC-Sr04. I was experimenting with it and have managed to make a relatively accurate distance sensor. However, i tried to make an led light up when the distance dropped below a certain amount, but it did not work. The distance measurements are still working properly, however the led instead of lighting up just has a very faint tiny glow which does not change no matter what I do.
This is my code:
const int trig = 8;
const int echo = 9;
const int led = 7;
pinMode(trig, OUTPUT);
pinMode(echo, INPUT);
pinMode(led, OUTPUT);
digitalWrite(led, LOW);
float duration,distance;
digitalWrite(trig, LOW);
delayMicroseconds(2);
digitalWrite(trig, HIGH);
delayMicroseconds(10);
duration = pulseIn(echo, HIGH);
distance = (duration/2)* 0.0344;
if (distance < 15)
digitalWrite(led, HIGH);
Serial.println(distance);
What am I doing wrong?
your "if distance ..." is missing the else-Satement, where you change led from HIGH to low.
Well for one thing you only ever switch the LED on. You don't switch it off again when the distance isn't <15.
But if it is very dim then what value resistor do you have in series with it? What Arduino are you using?
Steve
slipstick:
Steve
I am using a 220 ohm resistor with an arduino mega
And how is the LED wired?
GND -- 220 -- LED -- Arduino
or
+5V -- 220 -- LED -- Arduino
zwieblum:
or
It is more like Arduino(digital pin)--220--LED--GND
And by the way can two brushed dc motors be controlled by an Arduino Mega along with a HC-Sr04 without an H-bridge
Ok, that should work, but maybe you have a LED from ancient times. Check the voltage on the pin when high and when low.
You can use small DC motors, but they have to be really small (<40mA current or > 125 Ohm), like pager motors, but you should use freerunning diodes (which only allows one way rotation) or live on the interestinmg side of eletronics (put the motor between 2 arduino pins, then you can play H-bridge).
BTW, have you modified your if-statement?
GreenYeti:
If you need to control both speed and direction of the motors then you need an H-bridge. If you only need to control speed then a couple of MOSFETs will do it. But you will need something.
Basically the motors and HC-SR04 can easily be CONTROLLED by a Mega. But motors must be POWERED separately. The Arduino pins can only safely provide tiny currents.
Steve
slipstick:
Steve
In what way shall I power them?
Ok apparently my led was the culprit, now once I swapped the led, the led emits a light of regular intensity. However, the led just stays alight for the entire time, instead of changing depending on the distance between it and the object.
So I am trying to make the HC-Sr04 detect the distance, and while it is detecting a servo will spin from 0- 180 degrees and if the distance is below 20 cm the servo will stop moving, however I have the electronics working well but I am struggling with the code, can someone help
GreenYeti:
Did you read and understand posts #3 and #4? Have you changed your code to reflect the advice?
As for the servo, the latest code you've shown us doesn't even try to do anything with a servo so I think we need to see your current code.
Steve
