I'm building a circuit to regulate humidity in a box using a humidity sensor, axial fan, and Peltier module. The humidity sensor would sense when the humidity rises above a certain level, which would activate the fan and the Peltier module. The humidity sensor would then measure when the humidity has lowered to a certain level, which would deactivate the fan and the Peltier module. The humidity sensor has a operating voltage range of 4 - 5.8 V, so it can be powered directly from the Arduino. The fan is 12 V, whilst the Peltier module would need a supply of 4 V and 1 A. They will be powered by a DC power supply, and two power supplies can be used if necessary.
Does anyone have any thoughts on building this circuit? I'm struggling to get my head around how to power the Peltier and Fan of different voltages, whilst the Arduino controls when they are activated. I'm a bit of a novice with Arduino so any tips would be greatly appreciated.
Peltier Module: https://uk.rs-online.com/web/p/peltier-modules/1743132
Humidity Sensor: https://uk.rs-online.com/web/p/temperature-humidity-sensor-ics/5283171?cm_mmc=UK-PLA-DS3A-_-google-_-CSS_UK_EN_Semiconductors_Whoop-_-Temperature+%26+Humidity+Sensor+ICs_Whoop-_-5283171&matchtype=&aud-826607888827:pla-420937719811&gclid=EAIaIQobChMI4ND4xr-B9gIVDO7tCh0rEAWqEAQYAiABEgKCYvD_BwE&gclsrc=aw.ds
Thanks!!
