I am trying to build a custom remote to control several of my HiFi & TV systems from a single remote.
To start testing, I have an Adafruit IR receiver wired to an Uno and I'm using example code from the IRremote library:
* SimpleReceiver.cpp
* Demonstrates receiving ONLY NEC protocol IR codes with IRremote
* If no protocol is defined, all protocols (except Bang&Olufsen) are active.
* This file is part of Arduino-IRremote https://github.com/Arduino-IRremote/Arduino-IRremote.
* MIT License
* Copyright (c) 2020-2025 Armin Joachimsmeyer
* Permission is hereby granted, free of charge, to any person obtaining a copy
* of this software and associated documentation files (the "Software"), to deal
* in the Software without restriction, including without limitation the rights
* to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
* copies of the Software, and to permit persons to whom the Software is furnished
* to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in all
* copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED,
* INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
* PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
* HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF
* CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE
* OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
#include <Arduino.h>
* Specify which protocol(s) should be used for decoding.
* This must be done before the #include <IRremote.hpp>
//#define DECODE_DENON // Includes Sharp
//#define DECODE_JVC
//#define DECODE_KASEIKYO
//#define DECODE_PANASONIC // alias for DECODE_KASEIKYO
//#define DECODE_LG
//#define DECODE_NEC // Includes Apple and Onkyo. To enable all protocols , just comment/disable this line.
//#define DECODE_SAMSUNG
//#define DECODE_SONY
//#define DECODE_RC5
//#define DECODE_RC6
//#define DECODE_BOSEWAVE
//#define DECODE_LEGO_PF
//#define DECODE_MAGIQUEST
//#define DECODE_WHYNTER
//#define DECODE_FAST
//#define DECODE_DISTANCE_WIDTH // Universal decoder for pulse distance width protocols
//#define DECODE_HASH // special decoder for all protocols
//#define DECODE_BEO // This protocol must always be enabled manually, i.e. it is NOT enabled if no protocol is defined. It prevents decoding of SONY!
//#define DEBUG // Activate this for lots of lovely debug output from the decoders.
//#define RAW_BUFFER_LENGTH 750 // For air condition remotes it may require up to 750. Default is 200.
* This include defines the actual pin number for pins like IR_RECEIVE_PIN, IR_SEND_PIN for many different boards and architectures
#include "PinDefinitionsAndMore.h"
#include <IRremote.hpp> // include the library
// Just to know which program is running on my Arduino
Serial.println(F("START " __FILE__ " from " __DATE__ "\r\nUsing library version " VERSION_IRREMOTE));
// Start the receiver and if not 3. parameter specified, take LED_BUILTIN pin from the internal boards definition as default feedback LED
IrReceiver.begin(IR_RECEIVE_PIN, ENABLE_LED_FEEDBACK);
Serial.print ("IR_PIN: ");
Serial.println(IR_RECEIVE_PIN);
Serial.print(F("Ready to receive IR signals of protocols: "));
printActiveIRProtocols(&Serial);
Serial.println(F("at pin " STR(IR_RECEIVE_PIN)));
* Check if received data is available and if yes, try to decode it.
* Decoded result is in the IrReceiver.decodedIRData structure.
* E.g. command is in IrReceiver.decodedIRData.command
* address is in command is in IrReceiver.decodedIRData.address
* and up to 32 bit raw data in IrReceiver.decodedIRData.decodedRawData
if (IrReceiver.decode()) {
* Print a summary of received data
if (IrReceiver.decodedIRData.protocol == UNKNOWN)
Serial.println(F("Received noise or an unknown (or not yet enabled) protocol"));
// We have an unknown protocol here, print extended info
IrReceiver.printIRResultRawFormatted(&Serial, true);
IrReceiver.resume(); // Do it here, to preserve raw data for printing with printIRResultRawFormatted()
IrReceiver.resume(); // Early enable receiving of the next IR frame
IrReceiver.printIRResultShort(&Serial);
IrReceiver.printIRSendUsage(&Serial);
* Finally, check the received data and perform actions according to the received command
if (IrReceiver.decodedIRData.flags & IRDATA_FLAGS_IS_REPEAT) {
Serial.println(F("Repeat received. Here you can repeat the same action as before."));
if (IrReceiver.decodedIRData.command == 0x10) {
Serial.println(F("Received command 0x10."));
// do something
} else if (IrReceiver.decodedIRData.command == 0x11) {
Serial.println(F("Received command 0x11."));
// do something else
This works fine, I can point remotes at it and the Uno will report what it sees.
So I set up a Nano Every with code from the same library to transmit using an Adafuit superbright 5mm IR led (part 388A) using this code:
//#include <IRremote.hpp>
* SimpleSender.cpp
* Demonstrates sending IR codes in standard format with address and command
* An extended example for sending can be found as SendDemo.
* Sending IR codes using several pins for sending is implements in the MultipleSendPins example.
* Copyright (C) 2020-2025 Armin Joachimsmeyer
* armin.joachimsmeyer@gmail.com
* MIT License
#if !defined(ARDUINO_ESP32C3_DEV) // This is due to a bug in RISC-V compiler, which requires unused function sections :-(.
#define DISABLE_CODE_FOR_RECEIVER // Disables static receiver code like receive timer ISR handler and static IRReceiver and irparams data. Saves 450 bytes program memory and 269 bytes RAM if receiving functions are not required.
#endif
//#define SEND_PWM_BY_TIMER // Disable carrier PWM generation in software and use (restricted) hardware PWM.
//#define USE_NO_SEND_PWM // Use no carrier PWM, just simulate an active low receiver signal. Overrides SEND_PWM_BY_TIMER definition
pinMode(LED_BUILTIN, OUTPUT);
Serial.print(F("Send IR signals at pin "));
Serial.println(IR_SEND_PIN);
* The IR library setup. That's all!
IrSender.begin(); // Start with IR_SEND_PIN -which is defined in PinDefinitionsAndMore.h- as send pin and enable feedback LED at default feedback LED pin
disableLEDFeedback(); // Disable feedback LED at default feedback LED pin
IrSender.sendSamsung(0x7, 0x2, 0); // TV on and off - does not work
IrSender.sendNEC(0x7C87, 0x88, 0); // NAD volume up. Protocol=NEC Address=0x7C87 Command=0x88 Repeat Gap=38400us Duration=11750us
* Set up the data to be sent.
* For most protocols, the data is build up with a constant 8 (or 16 byte) address
* and a variable 8 bit command.
* There are exceptions like Sony and Denon, which have 5 bit address.
uint8_t sCommand = 0x34;
uint8_t sRepeats = 0;
return;
* Print current send values
Serial.print(F("Send now: address=0x00, command=0x"));
Serial.print(sCommand, HEX);
Serial.print(F(", repeats="));
Serial.print(sRepeats);
Serial.println(F("Send standard NEC with 8 bit address"));
Serial.flush();
// Receiver output for the first loop must be: Protocol=NEC Address=0x102 Command=0x34 Raw-Data=0xCB340102 (32 bits)
IrSender.sendNEC(0x00, sCommand, sRepeats);
* If you want to send a raw HEX value directly like e.g. 0xCB340102 you must use sendNECRaw()
// Serial.println(F("Send 32 bit LSB 0xCB340102 with NECRaw()"));
// IrSender.sendNECRaw(0xCB340102, sRepeats);
* If you want to send an "old" MSB HEX value used by IRremote versions before 3.0 like e.g. 0x40802CD3 you must use sendNECMSB()
// Serial.println(F("Send old 32 bit MSB 0x40802CD3 with sendNECMSB()"));
// IrSender.sendNECMSB(0x40802CD3, 32, sRepeats);
* Increment send values
sCommand += 0x11;
sRepeats++;
// clip repeats at 4
if (sRepeats > 4) {
sRepeats = 4;
delay(1000); // delay must be greater than 5 ms (RECORD_GAP_MICROS), otherwise the receiver sees it as one long signal
This works too in test - it sends signals to the Uno receiver and it reports them the same way as it does when I press the matching button on the remote.
However, when I test the Nano circuit agains the TV or amplifier, nothing happens. I'm at a bit of a loss as to how to debug this.
