Is there a way to build a long string, without terminating nulls between phrases, using a structure similar to the following? Having the sub-strings on individual lines is important for readability and comments. All the sub-strings are identical in length.
char* const text PROGMEM = {
"string1", // comments
"string2", // more comments
"string40" } ;
Remember that the array name TEXT is in fact a pointer and is the base address of the array, so any reference to PROGMEM would be relative to the base address plus the offset which is the index into the array.
Dr_Quark:
Thanks, now I just need to learn how to read one substring at a time into a RAM string so I can lcd.print() it.
If all you want to do is print it, you don't need to read it into RAM yourself. Assuming the 'Lcd' class inherits from the 'Print' class, its 'print' method knows how to deal with a '__FlashStringHelper *'. So, with proper casting, you can get the lcd object to do the reading into RAM for you.
gfvalvo:
Posting 40 lines of code is not "explaining." Don't let your 7,000 posts convince you that you're a gift to clarity. I do appreciate the effort you put in, but it was over my head without accompanying text.
The obvious answer is to null terminate each string, at which point using flashStringHelper or other flash-to-ram copy functions becomes a lot easier.
Why did you want to get rid of the nulls?
const char TEXT[] PROGMEM = "Token1\0" // Comments
"Token2\0" // More comments
"Third0\0"
"Fourth\0"
"Last o\0"; // Yup, the end!
char c = Serial.read();
if (c > ' ') { // only listen to "real" characters.
int whichToken = c & 7; // strip off bits to make char a small int index.
// Each token is 7 bytes (including the null), so an char index is 7 * the token index
int whichChar = 7 * whichToken;
// A flash string pointer is constructed by adding the char index to the start, and "casting."
__FlashStringHelper *f = (__FlashStringHelper *) (TEXT + whichChar);
Serial.println(f);
(using "\0" puts nulls in the single string, instead of the issues you get with an array of character pointers that don't necessarilly point to flash.)
