hi, my name is Thomas
and I am new to arduino and this forum.
I'd like to present you the project I'm working on,
and maybe you got some guidance for me.
Well i need some I guess.
As a musician I'm working with apples MainStage, which ist great but lacks any sort of automation, so I got me a Teensy and a bunch of Tutorials.
My style is Ed Sheehanish Acoustic Guitar looping.
Here's the need:
the ability to run a certain sequence depending on the incoming Midi program change.
Everything Synced, of course, MainStage mostly gets Midi NoteOn/Off commands.
one switch starts/stops MainStage.
the second switch will have two functions:
a) start the Arduino „sequence“, starts the „count“ (Ticks, bars, measures)
b) rewind to certain points in that running sequence.
That's for example: on measure 7, tick 90 the sequence starts one of MainStage Loopers at Measure 8.
now on measure 9 I make a mistake, I hit that button again, the sequence „rewinds“ to the same position (say... tick 78) in measure 7, commands are sent to stop and clear the looper.
I think I can get through all the things I need (I didn't try that rewind stuff yet), but only with a whole lot of if/else /while loops and huge amounts of variables and code.
Here is what I got so far, please have a look at it, I bet there's a more sophisticated approach to this. e.g. I tried to work with Function Pointers, but with little success...
thanks
Code starts here:
const byte START = 250;
const byte STOP = 252;
const byte CLOCK = 248;
// variables for recieved MidiClockTicks, resulting Beats and full measures
byte tick = 0;
byte schlag = 0;
byte takt = 1;
// variables for the switch and its resulting state (see void loop())
int S1 = HIGH;
int S1_1 = HIGH;
bool ply = false;
//variable for recieved Midi ProgramChange
byte programNum = 0;
// give the midi notes to be sent a good name
#define start_stop 40
#define allstop 43
#define L1_playstop 41
#define L1_stop 42
pinMode(12, INPUT_PULLUP);
pinMode(13, OUTPUT);
usbMIDI.setHandleProgramChange(myProgramChange);
usbMIDI.setHandleRealTimeSystem(beatClock);
Serial.begin(312500);
int S1 = digitalRead(12);
if (S1 == LOW && S1_1 == HIGH) {
usbMIDI.sendNoteOn(start_stop, 127, 1); S1_1 = S1;
if (S1 == HIGH && S1_1 == LOW) {
usbMIDI.sendNoteOff(start_stop, 0, 1); S1_1 = S1; ply =! ply;
usbMIDI.read();
//if there is a program change, catch the program number and stop it all with halt()
void myProgramChange(byte channel, byte program) {
programNum = program; halt();
void beatClock(byte realtimebyte) {
if(realtimebyte == START) {// reset with each START from the host
tick = 0;
takt = 1;
schlag = 0;
if(realtimebyte == STOP) {//well, stop...
halt();
//„play“ the commands of Song according to number of program
if(programNum == 1) {
song_01(realtimebyte);
if(programNum == 2) {
song_02(realtimebyte);
void song_01(byte realtimebyte) {
// if there is ticks coming AND I pressed „play“
if(realtimebyte == CLOCK && ply == true) {
// increase tick with each recieved Midi Click
tick++;
//reset to 1 after 96 click (= full measure)
if(tick % 97 == 0) {
tick = 1;
// Blink part one and increase the number of Beats every 24 ticks
if(tick == 1 || tick == 25 || tick == 49 || tick == 73) {
digitalWrite(13, HIGH);
schlag++;
// reset beats to 1 depending on 3/4 or 4/4 Measure
if(schlag % (5) == 0) {
takt++;
schlag = 1;}
// Blink part two
if(tick == 10 || tick == 26 || tick == 50 || tick == 74) {
digitalWrite(13, LOW);
serialPrint();
if(takt == 2 && tick == 90) {befehl(L1_playstop);} //the commands
if(takt == 4 && tick == 48) {befehl(L1_playstop);}
if(takt == 4 && tick == 90) {befehl(L1_playstop);}
if(takt == 5 && tick == 90) {befehl(L1_playstop);}
if(takt >= 8) {halt();}
void song_02(byte realtimebyte) {// see above...
tick++;
tick = 1;
digitalWrite(13, HIGH); schlag++;
takt++; schlag = 1;
serialPrint();
if(takt == 3 && tick == 90) {
if(takt == 5 && tick == 48) {
if(takt == 6 && tick == 90) {
if(takt == 7 && tick == 90) {
if(takt >= 8) {
halt();
void serialPrint(){ //self explanatory?
Serial.print(takt);
Serial.print(" / ");
Serial.print(schlag);
Serial.println(tick);
void befehl(byte note) { //function for sent commands
usbMIDI.sendNoteOn(note, 127, 1);
usbMIDI.sendNoteOff(note, 0, 1);
void halt() { //stop and reset everything
takt = 1; schlag = 0;
usbMIDI.sendNoteOn(allstop, 127, 1);
usbMIDI.sendNoteOff(allstop, 0, 1);
befehl(L1_stop);;
ply = false;
Tippe oder füge den Code hier ein
