BrownDog186:
for the chassis its most likley going to be just a alluminuim hobby box with some fans and filters [duct i will be going in has a build up of at least 20 years of dust and mould so will be sealed]
will be controlled just by an ethernet cable, tied together with a power supply for it, and twitsted on some rope and covered in tape of some kind so its protected and pullable
Based on this description (and little else) - I can't imagine that the robot will have enough traction or power to pull along any great length of such a cable and safety line. Also note that ethernet cable (that is, the usual stuff from a box) is made of solid core wires; stranded core cable does exist, but it isn't cheap.
This is why I postulated a wireless approach - it would allow the robot to be smaller, and lighter weight, yet still gain you plenty of functionality (assuming that it worked inside the ductwork, of course).
BrownDog186:
cameras will just be some USB web cams
How do you intend to get the USB signal back? You can't just wire it "direct" - USB is only good for a few meters of cable; you'll need boosters/amplifiers, etc - and you'll need a hub on the robot end to connect it all up - unless you plan to put something on that end (like a small embedded computer like the Raspberry Pi) that can talk USB to multiple devices and send it back along one way. Note, though, that the Pi's USB isn't actually done with multiple ports (IIRC) - but rather is like a "hub" - so speeds and other things when using multiple devices will be affected.
This can all be avoided if you go with ethernet and a switch.
BrownDog186:
will be driven tank track style as it allows for small turning circle
That's a good plan for such a robot. But note that you could also get away with four-wheel differential skid-steer, which might work just as well in the task, and be easier to source parts for (mainly the treads - sometimes those are easily available, other times they aren't).
BrownDog186:
if i can get it setup to be controlled by a custom controller [just a box with a single joystick and potentiometers to control diming of the lights] and the webcams viewed on the laptop that would be perfect
Perfect for the beta, maybe - but if I were going to develop this as a product for sale to others (let's be honest, I bet that is what your boss is thinking of doing) - the controller (and recording, etc) - would all be done via a smartphone.
Which - again - wireless ethernet (802.11) would be perfect for.
The more I talk about this, the more I think that I should get off my duff and just build one and market it myself to local inspection businesses and individuals; it's something I've thought about for a long while, and I have all the skills to do it - and heck, I probably have all the parts laying around in my shop to boot. I'm just a bum, I guess...lol.
