Can't get a multi-file/multi-tab project to build. I created a skeleton sketch to test multi-file building, and even this simple conception fails to build.
== Compiler/linker error: =============================
libkoe.cpp.o: In function loop': C:\Users\X\AppData\Local\Temp\build6301035900337716840.tmp/libkoe.cpp:11: undefined reference to
lib_loop()'
libkoe.cpp.o: In function setup': C:\Users\X\AppData\Local\Temp\build6301035900337716840.tmp/libkoe.cpp:7: undefined reference to
lib_setup()'
Source files/tabs:
=== libtest: (main file)===========================
#include "lib.h"
lib_setup();
lib_loop();
=== lib.h: =======================================
#ifndef LIB_H
#define LIB_H
void lib_setup();
void lib_loop();
#endif
=== lib.c: =======================================
#include "lib.h"
void lib_setup() {
void lib_loop() {
Are there some settings to tweak to get this going?
Should I use C++ style source files when creating multi-file projects?
Something messed up in my environment?
Originally I tried to create a library (in libraries directory).
thanks for your time!
