Building a wireless environment sensor capable of running for almost 2 years on a single CR2032:
Intro
This article will discuss and demonstrate how to build a remote Temperature and Humidity sensor based on a Whisper Node and a DHT11 (worst sensor ever, I know)., capable of running for well over a year on a single CR2032 coin-cell.
The remote node will be configured to transmit data every 60 seconds to another Whisper Node, acting as a gateway/base station and located 100 meters away. The data will be finally uploaded to a Google Could server running InfluxDB and Grafana to display the data.
continue at: Temp. And Humidity Sensor With A CR2032 For Over 1 Year! - Hackster.io
Lots of detail on power and configuration. But little RF detail:
? What is the modulation mode
? What is the expected range?
? What is the receiver sensitivity
? What signal processing is done, with what effect on needed SNR?
Is this LoRa or other? What communication / standard? Interoperability with anything else?
Just so much activity in this area, hard to follow it all...
Hey Terry,
Yes I agree there are lots of RF options at the moment. Well the Whisper Node has RFM69W built-in (http://www.hoperf.com/upload/rf/RFM69W-V1.3.pdf). It's a subGhz digital module based on the Semtech SX1231.
This is not LoRa. Here the main features:
Modulations: OOK, FSK and GFSK
TX Power: 13dBm (20dBm for the High power version)
RX Sensitivity: -120dBm at lower bit-rates
The Power consumption for TX varies according to the TX power, I've documented it here: Bitbucket
The TX mode consumes around 16mA.
I'm currently using the RadioHead Driver: RadioHead: RH_RF69 Class Reference
For the application protocol you can basically use anything, but I normally use with very short binary messages to preserve energy. Here an example how I pack the messages: https://bitbucket.org/talk2/talk2-library/src/master/examples/02.Comms/Voltage.node/Voltage.node.ino?at=master, which is basically a "clone" of a CAN Bus frame "b", headers + 8 bytes of payload.
In terms of Interoperability, you can talk with any other device using RFM69 or Semtech SX1231.
Hope I clarified most of your question. Soon I'll be including the AVR and Python code, as well the steps to install and built the Grafana dashboard.
Update: regarding the range, as all wireless related it varies. The project in the original post is designed to handle 100m at higher speeds, but here some tests I did at lower bit-rages (19200bps):
