Hey! I want to sample two analog inputs voltage & current into an array. I will want to take maybe 0.5 seconds of data (35 periods) at 500-1000 Samp/sec (250-500 points per signal per second), then transfer the arrays to labview and do the phase calculation.
Here is my code:
const int analogIn0 = A0;
const int analogIn1 = A1;
int mVperAmp = 185; // use 100 for 20A Module and 66 for 30A Module
int RawCurrentValue= 0;
int RawVoltageValue= 0;
int ACSoffset = 2500;
int Denominator = 0;
float AcVoltage = 0;
float Voltage0 = 0;
float Voltage1 = 0;
float Amps = 0;
int RawCurrentValue[250] ; // Declare array for Current samples
int RawVoltageValue[250] ; // Declare array for Voltage samples
void loop(){
// Collect a burst of 250 Voltage and Current samples
for (int k=0 ; k < 250 ; k += 1)
RawCurrentValue[k] = analogRead(analogIn0);
RawVoltageValue[k] = analogRead(analogIn1);
delay(2) ; // Delay to get desired sample interval
Denominator = (10000)/(130000);
// Calculate standard values of Voltage and Current and send to serial port
Voltage0 = (RawCurrentValue[k] / 1023.0) * 5000;
Voltage1 = (RawVoltageValue[k] / 1023.0) * 5000;
AcVoltage = (Voltage1 / Denominator ) ;
Amps = ((Voltage0 - ACSoffset) / mVperAmp);
Serial.print(Amps);
Serial.print(", ");
Serial.println(AcVoltage);
Since Arduinos typically don't have much RAM, the array sizes are limited so you're probably going to have to settle for less than 500 samples. In the code above, I've saved the raw A/D reading because INT is a two byte value and the floating point representation computed later in the code is a REAL four byte value, that is the INT take up half as much RAM per sample.
If you need 500 data point, use a MEGA2560. It has 8KB memory for up to 4,000 analog readings, maybe 3,800 realistically since by default all 4 Serial ports are active and take memory as buffer space. This way you will have nearly 2000 samples.
How does labview read data from the serial port? Are you using something like VISA to open serial port and feeding the text string through some string operations?
512
That plus pointers, regardless you use all 4 serial ports or not. I was trying to NOT involve any numbers. If you want some reading, you can find it here:
Then I provided you just enough information to see they are all using space. The buffers are static arrays and all 4 serial objects are created with the buffers.
I don't ban people for not knowing things - what a peculiar notion!
People get banned for wilfully ignoring simple guidelines designed to help people get help, or simply being wilfully stupid.
You're not in any danger of banning.
Am I short? (I'm 1.85 m tall, so no, I don't think so)
My best and favourite CS lecturer had a really great way of testing if you'd done your groundwork. Students would present their work and their conclusions, he'd take notes, ask a few questions, and then say something simple and innocuous like "Are you sure about that?" or "Are you happy with that?"
It usually meant he'd spotted something you hadn't, and you had to think fast.
Sometimes as he said it, there was the hint of a chuckle or there was a twinkle in his eye, and you knew you'd done OK.
But you never ignored even the simplest of his questions.
I think it's a valid technique, well over thirty years on.
void loop(){
Thanks for the replies!
But I do not understand the "delay(2) ; // Delay to get desired sample interval" What do you mean and what happens if I increase or decrease the delay?
lamela:
that is, 1 sample every 1 to 2 milliseconds. Ignoring the overhead of the sampling loop and the digital data reads, "delay(2)" gives you a sample every 2 milliseconds. In reality it's going to be about 2.2 milliseconds because the AnalogReads are on the order of 100 microseconds each plus a handful of microseconds for the loop overhead. "delay(1)" would put the sample rate in your specified range, but higher sampling rate means a shorter data collection given the limited RAM available.
