I have a telemetry project using a Mega 2560 and have a few instances of these in different locations.
As I'm doing some bug fixes and adding new features it's getting a little tedious always changing the MAC and IP addresses in the sketch for each one and then uploading the new code.
Is there a better way to build / write a project that has a configuration that can be scaled up so it's easier to manage?
Mind you, you probably will need to have a separate sketch to load the data into the EEPROM, perhaps by typing it into the Serial Monitor (and using the same sketch to verify).
