Hi guys
First of all, thanks for the add.
Thanks for existing of this forum, good bless everyone who it is putting his time and knowledge into this forum to help us having a better hobby life.
I need help, a lot of help.
I want to build my own aquarium controller, a huge challenge for me. I know with help I can due.
Idea it is to build a system which will control everything.
The systems to be compose by more sub-systems. Each sub-system will work under the main systems control.
I will need a few basic function to be in place as: dimming, timer, faze, ETC.
I will make a short description of my goal.
I will make a list and after that I will count down to put all together to make a short list to see where I'm with my ideea and what exactly I'm going to do. I will mention all my sub-systems which will be working on my aquarium controller.
Filter system made of:
2x electric valve (to close and open the pipe circuit)
1x fully submersible pump which need to be dimmable.
CO2 system made of:
2x water valve (work as a tap, open/close the water line/pipe, one for each end of water line, one for entrance/intake of water into the pipe and another one at the end of water line before exit of water from the water line)controleted by CO2 sub-systems but also connected to the main controller and must open/close simultaneous.
1x electronic air pressured valve
1x pump in line for water in and out
1x co2 reactor which contain
1x wave maker in the chamber of CO2 reactor
1x PH/CO2 probe reader (one of them or both if you want to know the amount of CO2 dissolved in water for reaching the specific PH).
Ideal to have one CO2 probe reader also connected
O2 systems made of:
2x water valve (work as a tap, open/close the water line/pipe, one for each end of water line, one for entrance/intake of water into the pipe and another one at the end of water line before exit of water from the water line) also connected to the controller and must open/close simultaneous.
1x electronic air pressured valve/ air pump,
1x pump in line for water in and out,
1x O2 reactor which contain 1x wave maker in the chamber of O2 reactor,
1x Dissolved O2 probe reader.
O3 system made of:
1x O3 generator
1x air pump
1x O3 reactor which contain
1x wave maker in the chamber of O3 reactor
1x ORP probe reader
Lighting systems made of: all LED channel must be dimmable
UV-C SS-LED (ultra violet super bright Light emitter diode) 2 CH
SS-LED 16 CH for different colour individual controlled
Cooling and heating system made of:
Cooling systems:
1x fridge for cooling device
Heating systems
1x 400W heater or 2x 200W heater
Dosing pump system made of
8x peristatic dosing pump (for plant feeding and water treatment)
Feeding system made of
1x dosing pump (the motor part only to be use as it is easy to control the food dosage)
ATO system made of
1x pump in line for water out
4x water level sensor
RO system made of
3x water valve (work as a tap, open/close the water line/pipe, one for each end of water line, one for entrance/intake of water into the pipe and another one at the end of water line before exit of water from the water line) also connected to the controller and must open/close simultaneous.
1x designated water pump in line for water in RO system
1x RO system
I know it is a huge list of peripherals to be connected, the good news it is that this device will not work all at the same time, they will be connected all at the same time but will work in a patent. It may be a moment when will work more than half of them but never all of them.
Let’s see:
Filter always ON only OFF when water change
Light UV always ON
LED ON and OFF by patent
O2 systems by patent (depend of reading) but always OFF when water change
O3 systems by patent (depend of reading) but always OFF when water change
CO2 systems by patent (depend of reading) but always OFF when water change
RO system always OFF but ON when water change
ATO system always OFF but ON when water change also standby for top-ups when needed
Cooling system by needed but never ON at the same time with the heating systems
Heating systems by needed but never ON at the same time with the cooling systems
Explanation
Cooling and heating systems work as a pair, the way how it is done will be as a switch between them when one it is ON another one it is OFF and vice versa. The electro valves are synchronised with the paired system so when one of the system it is ON or OFF the valves which are paired with that system will also be ON or OFF by the case.
During water change both systems are switched OFF to prevent any gas to accumulated in any parts of them components.
O2, O3, CO2 will be switched OFF during water change to prevent any gas to accumulate on the reactor chamber. The electro valves are synchronised with the paired system so when one of the system it is ON or OFF the valves which are paired with that system will also be ON or OFF by the case, each system will have his separates pair of synchronised electric valves. One, two or all three systems can be ON or OFF at the same time. Here need to be available a delay switches off option for different pieces which made the systems (see my first e-mail for details).
ATO and RO systems, first will start RO system and will run until it is removed 25% from the total amount of the water from my fish tank (water level sensor will control the running of RO systems giving the signal for ON and for OFF), (the amount of 75% remained will included the pure H2O from the RO system which was send back by RO system. When the total volume it is 75% left in my fish tank (trigged by water level sensor) the RO system stop and then start ATO until it is rich 100% of water in my fish tank (trigged by water level sensor) and then ATO system stop and all electrics valve are switched off.
External filter will be ON always, OFF only when water change happens, the electric valve will also be ON or OFF by the case (synchronised with the filter).
The short list:
V=voltages
1x fully submersible powerful water pump-220V possible 24V, need to look
17x electric water valve-5V/12V
1x CO2 electronic air valve-220V possible lower V, need to look
6x water pump in line for water in and out-5V/12V/24V
3x wave maker in the chamber of gas reactor-220V available lower V, need to look
1x PH probe reader
1x CO2 probe reader
1x electronic in line air pressured valve-220V possible lower V, need to look
2x air pump-220V possible lower V, need to look
1x O3 generator-220V
1x ORP probe reader
2x CH UV-C SS-LED (ultra violet super bright Light emitter diode)-5V/12V/24V
14x CH SS-LED for different light colour individual controlled -5V/12V/24V
1x small fridge for cooling device-220V
1x 400W heater or 2x 200W heater-220V
9x peristatic dosing pump-12V possible 5V, need to look
1x designated water pump in line for water in RO system 12V
1x RO system-12V
Many thanks for understanding and helping me. Any idea it is more than welcome and very appreciates. I’m happy to share my project and my idea with anyone and if somebody want to build something similar or to use my idea it is more than welcome. If somebody need more details about the hardware I’m happy to help with the peripheries and how I made them.
Many thanks again.
I look forward for your comments.
Thank you.
