Hello!
Has anyone managed to build the tools for the Arduino using Slackware Linux using the ideas described here: Arduino Playground - Slackware?
Those strange characters are actually the "--" that the configure scripts use to assist the specialty features to be setup.
I've got it currently building on a Slackware 11.0 system and did succeed in building it on a 12.1 system. Naturally someone went ahead and built it for that system release.
I find this to be an interesting concept because Slackware happens to be the oldest distribution still being continuously updated and released, and even used.
This because you need to click Slackware on the site to see what is the suggested method.
And of course since I normally use Windows for the whole process of creating a sketch and trying it out on the destination device, I didn't realize that a specially prepared copy of AVRdude was needed on Linux.
Well anyway I'll know if it works, but I am also interested in packages for 11.0 of Slackware.
If you run your SlackWare distribution on a x86 machine there should be no need to re-compile the avrdude-version the Arduino-Ide uses.
And apart from that you need only a JavaRuntime.
And there is also nothing magic with the Arduino-specific AVRDude-binary. In one of my own projects Google Code Archive - Long-term storage for Google Code Project Hosting. I upload the sketches with the AvrDude-binary that comes with the distribution. The only thing you currently need is the "avrdude.conf" from the Arduino-IDE because this file is out-of-date on many distributions in respect to the atmega328p.
never used slackware, but I'm pretty sure there are pre-built packages for "avrdude, avr-gcc and avr-libc" ready to install. This shpould be all you need.
Hello!
And I've been to the site already. They do not have a set created for 11.0. Just for 12.1 made up. Now I might be so inclined to install that one, and hopefully it will work for me for that system.
But I've got two up and running for supporting older applications who needed even older hardware. But that's for the PC side of things, not for the Arduino.
I believe we've reached an interesting stopping point.
