Hi everybody!
I'm designing a frequency detector for guitar.
It works great!
Now I'm trying to use the built-in analog comparator instead of using an external one to save even more PCB space!
The idea is to use the input capture feature on timer 1.
My problem is that for some reason the Comparator doesn't seem to handle frequencies higher than 120Hz or so. I'm using software to do different stuff if the comparator output is on a rising edge, or on a falling edge.
Here is a stripped down version of my code that I used for testing.
Maybe it's my way of adding software hysteresis that is weird?
My audio is biased around 2.5v going to the positive input, and 2.5v is applied on the negative input of the comparator.
byte Hysteresis=0;
pinMode(6,INPUT); //AIN0 positive input of comparator
pinMode(7,INPUT); //AIN1 negative input of comparator
pinMode(13,OUTPUT); //Comparator output visualisation for oscilloscope.
ADCSRB |= (1<<ACME); //AIN1 to negative input
ACSR &= ~(1<<ACD); // No Disabling
ACSR &= ~(1<<ACBG); //no bandgap
ACSR |= (1<<ACIE); //enable interrupt
//ACSR |= (1<<ACIC); //enable input capture from comp (+ICIE1)
ACSR &= ~(1<<ACIS1); //both at 0: rising AND falling edge detector
ACSR &= ~(1<<ACIS0);
DIDR1 &= ~(1<<AIN1D); // enables the digital input pins buffers
DIDR1 &= ~(1<<AIN0D);
//TIMSK1 |= (1<<ICIE1); // enable input capture
TCCR2A &= ~(1 << COM2A1); //
TCCR2A &= ~(1 << COM2A0); //these 2 bits disable the OC1A when not in PWM mode
TCCR2A &= ~(1 << COM2B1); //
TCCR2A &= ~(1 << COM2B0); //these 2 bits disable OC1B when not in PWM mode
TCCR2A &= ~(1 << WGM21); //all 3 WGM bits to 0 is normal mode
TCCR2A &= ~(1 << WGM20);
TCCR2B &= ~(1 << WGM22);
TCCR2B &= ~(1<< CS22); // these 3 next bits set pre-scaler to 1
TCCR2B &= ~(1 << CS21); //
TCCR2B |= (1 << CS20); //
TIMSK2 &= ~(1 << OCIE1B); //disable output compare B Interrupt
TIMSK2 &= ~(1 << OCIE1A); //disable output compare A Interrupt
TIMSK2 |= (1 << TOIE1); //enable overflow interrupt
ISR (ANALOG_COMP_vect) {
if (Hysteresis==0) {
if ((ACSR >> ACO) & 1) {
Hysteresis=1;
PORTB |= (1<<5); // D13 high
Hysteresis=1;
PORTB &= ~(1<<5); // D13 low
ISR (TIMER2_OVF_vect) {
if (Hysteresis!=0) {
Hysteresis++;
else if (Hysteresis==4) {
Hysteresis==0;
The comparator output visualized on pin D13 looks ok for the 5 or 6 first low notes on the guitar.
When I go higher, I either get a high state, a low state, or a frequency less than 120Hz.
I'd like the frequency range to go from 39Hz to 1300Hz.
What do you think is the problem?
