Hi! I uploaded to my mega 2560 the blink example and it made blink the BUILTIN led. But when I tried it slightly the same way it made blink the rx led and the delay function didn't work well.
I mean when I set the led HIGH and made a 1000 delay it didn't waited.
Why is that?
int num = 0;
void blink(int num) {
int count = 1;
for( ; ; ) {
if(count == num) {
Serial.println("END");
digitalWrite(LED_BUILTIN, HIGH);
digitalWrite(LED_BUILTIN, LOW);
else {
Serial.println("ON GOING");
delay(150);
count++;
pinMode(LED_BUILTIN, OUTPUT);
blink(5);
If you look at a schematic for the Mega 2560, you'll see that while the LED_BUILTIN led is hooked up to the Mega, the Rx and Tx LEDs are not. They are connected to the 16u2.
Koepel
November 6, 2023, 11:22pm
3
The delay of 1000 works. Make it 10000 and count the 10 seconds.
@botond500
Are you sure the RX is blinking?
Wouldn't it be TX?
The TX will blink because you use the serial.
botond500:
for( ; ; ) {
if(count == num) {
else {
delay(150);
count++;
If you're talking about that code, try the following:
for( ; ; ) {
if(count == num) {
else {
delay(150);
delay(150);
count++;
I tried it first but it didn't work.
system
Closed
May 5, 2024, 6:46am
7
