Built-in Desktop PC Audio Part
I dismantled a junk computer to look at the built-in audio output device. See photo, attached. I hesitate to call the thing a speaker, but it is more complicated than a Piezo buzzer. It has four wires. Why? The computer lacked a sound card. Any audio content, from Internet for example, played on it, and, of course, start-up sounds.
I would like to make an Arduino project with it. Looking at 94V-0 printed on the part makes me hesitant. That seems a bit much for such a tiny component.
Any links to data sheet, forum thread, or otherwise is appreciated.
Pretty sure 94V-0 is just a part number. Can you use a strong light and magnifying glass to read the markings on the chip?
Okay, that 94V-0 is a part number (doh). Here's a link to a Google image search:
https://www.google.com/search?q=dell+speaker+94v-0&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwjjofT85YbUAhVqiFQKHRXzCRIQsAQIRQ&biw=1159&bih=1001#imgrc=evd42Z5PyudXhM:
This is the exact item, except the number 24 is a 30 on my part:
http://www.ebay.com.au/itm/Lot-of-10-Dell-Speakers-Sub-Assembly-8-Ohm-1-Watt-94V-0-New-Old-Stock-/330831981925
I will read more under the search results for a data sheet.
4 wires because it's amplified. Red for +5v, black for shared GND, and green for a mono audio signal. White you can ignore.
94V-0 is the flammability rating of the plastics used. It is NOT the part number.
Some reading stuff on the rating here
// Per.
Here is an article someone wrote about the one they had: https://www.contrapositivediary.com/?p=1758
