// code from https://github.com/arduino/arduino-examples/blob/main/examples/10.StarterKit_BasicKit/p08_DigitalHourglass/p08_DigitalHourglass.ino
// sim: https://wokwi.com/projects/422992836439284737
// for issue https://github.com/arduino/arduino-examples/issues/83
// about turning off out-of-bounds LEDs above pin 7
Arduino Starter Kit example
Project 8 - Digital Hourglass
This sketch is written to accompany Project 8 in the Arduino Starter Kit
Parts required:
- 10 kilohm resistor
- six 220 ohm resistors
- six LEDs
- tilt switch
created 13 Sep 2012
by Scott Fitzgerald
https://store.arduino.cc/genuino-starter-kit
This example code is part of the public domain.
// named constant for the switch pin
const int switchPin = 8;
unsigned long previousTime = 0; // store the last time an LED was updated
int switchState = 0; // the current switch state
int prevSwitchState = 0; // the previous switch state
int led = 2; // a variable to refer to the LEDs
// 600000 = 10 minutes in milliseconds
long interval = 600000/100; // interval at which to light the next LED
// set the LED pins as outputs
for (int x = 2; x < 8; x++) {
pinMode(x, OUTPUT);
// set the tilt switch pin as input
pinMode(switchPin, INPUT);
// store the time since the Arduino started running in a variable
unsigned long currentTime = millis();
// compare the current time to the previous time an LED turned on
// if it is greater than your interval, run the if statement
if (currentTime - previousTime > interval) {
// save the current time as the last time you changed an LED
previousTime = currentTime;
// Turn the LED on
digitalWrite(led, HIGH);
// increment the led variable
// in 10 minutes the next LED will light up
led++;
if (led == 7) {
// the hour is up
// read the switch value
switchState = digitalRead(switchPin);
// if the switch has changed
if (switchState != prevSwitchState) {
// turn all the LEDs low
digitalWrite(x, LOW);
// reset the LED variable to the first one
led = 2;
//reset the timer
// set the previous switch state to the current state
prevSwitchState = switchState;
Note that this speeds it up to 6-second steps, 36sec total. After 42 secs, when led==8, the digitalWrite(led,HIGH) pulls up the input, overriding the external pulldown and inhibiting button signal changes.
I think this forum post experienced the problem:
and this one:
I opened an issue at:
...with a suggestion that they limit the bounds of the led-energizing circuit with something like:
if (currentTime - previousTime > interval && led < 8) {
In this other forum post, I think the issue is that the stock sketch is incredibly boring, and that the first LED doesn't even turn on for 10 minutes (60000ms):
In the simulation linked above, I wired up an additional 6 leds (on a DIP) in active-LOW format to show that something happens.
