bulb 6v PWM?
any suggestion how i control this bulb. it's rated 6v 50mA.
Just like any other load, in this case I would use an external transistor or darlington.
I am not sure if the PWM will work but you can try.
You would need to use a transistor with a resistor.
like so:
Just instead of the relay put the bulb.
Yes it will, it will allow you to dim the bulb.
